Question about Hayward H Series Pool & Spa Heater Electronic Dual Ignition 400,000 Btu Natural Gas H400ed2
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF error intermittently. I replace igniter assembly as recommended by Hayward. That didn't help
    Problem Solver:
  • 15 Answers
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Posted on Aug 22, 2010
Hayward H400 error code IF (Ignition Failure)
yes, make sure you order the correct part, youll need the model number and serial number. the ignitor has 2 wires wrapped with white fibers, usually 2 screws to remove it, and theres only one way to plug it back in. NOTE: Ignition failure does not always mean the ignitor needs replaced. make sure your ignitor doesnt turn on and glow when you start the heater. if it does, youll want to clean out the gas orifices.
Apr 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
H400ed2 IF
(IF- Ignition Failure) It may be your flame sensor failing to recognize that the heater has fired. This will tell the gas valve to close if it does not detect a flame.
Dec 06, 2013 | Hayward H Series Pool & Spa Heater...
H400ed2 IF code
problem could me many things.....ensure proper gas pressure, proper voltage to spark igniter, all safeties are closed, etc
1F Error Code on Hayword Heater
IF stands of igniton failure. Many things can cause this. Most notable, is a clogged or dirty burner orifice. The two middle ones are the most important. But i would clean them all out. They remove with a 5/16" wrench. Improper gas pressure could also cause this. However, you need a special tool, a manometer, to read this.
May 05, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series 400,000 BTU Pool Heater Won't Ignite
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
May 25, 2009 | Hayward Pool Products Hayward 400k Lp H...
Hayward H Series Pool & Spa Heater Electronic Dual Ignition 400,000 Btu Natural Gas H400ed2 Logo
417 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
