Question about SAMTRON 55V 15" CRT Monitor
How to stop monitor menu pop up in my Desktop's CRT Monitor ? The menu pop up keeps coming back and I have to keep exiting manually using monitor menu buttons.
    Problem Solver:
  • 14 Answers
R u sure about model number.bcoz 55v does't come with menu.
replace regulator 7805 near microcontroller if it is model 56v.
Posted on Sep 07, 2010
2 Suggested Answers
SOURCE: crt monitor turned orange and the monitor menu keeps popping up
i have the same problem with my tv. i opened it up and cleaned the menu button with alcohol, then its went normal..for now
Posted on Jun 02, 2010
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Aug 03, 2010 | E-Machines eMachines Desktop PC
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Apr 21, 2010 | SAMTRON 55V 15" CRT Monitor
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor Menu Poping up again & again
1. First U can change Microswitches on front pannle (Menu,select,+,-)
2.check dry points in MICOM&EEPROM IC,HV IC and It's related.
3.check 5V supply and replace 5V Regulator.
Oct 05, 2008 | IBM E74 17" CRT Monitor
Troubleshooting
REPLACE FRONT SIDE OSD BUTTONS (EXIT,BRIGHTNESS,CONTRAST,MENU) IT IS MOISTURE PROBLEM
Aug 06, 2008 | IBM E74 17" CRT Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Menu screen keeps appearing
Hello, My name is Richard; I work for Dell here in Round Rock, Texas. From what you describe, it sounds like the menu button is depressed in such a way that small movement activates its function. I could not suggest any real corrective options as this is most likely a mechanical issue with the button, and would require a technician to open the monitor and inspect that. I am not going to recommend you open the monitor case as it can be dangerous. I would suggest you call our tech support at 1-800-822-8965 ex. 726-8859, and find out if the monitor is still under warranty. Regards, Richard B Dell Online Community Outreach
Apr 29, 2007 | Dell E773C 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
1,411 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
