Question about Microtek 710S 17" Flat Panel LCD Monitor
I have a 710S 17 in. Microtek monitor and everytime I try to change the resolution to anything bigger than 800x600, the screen turns black and says "Out of Range". What can I do to fix this?
  • 11,361 Answers
This monitor max resolution is 1280 x 1024, are you trying to go higher than this?
If not, then you kay have unstable DC in the power supply due to bad caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 22, 2010
My Microtek 710S Monitor screen goes black if left unattended for one minute. What do I do to keep this from happening?
Check the power setting of your PC.
  • If you are on windows;
  • Click on start button
  • If you have vista or windows 7, type "poweroptions" into the search bar.
If not, open control panel and find the power options inthere
  • In "power options" you can change when the displaygets turned off and when your PC will go to sleep, just change these settingsto the time you want, e.g. 2hours
I can offer support for other OS if required
Mar 02, 2011 | Microtek 710S 17" Flat Panel LCD Monitor
How to repair monitor
What is the problem with monitors? Flashes on then goes black? See example of failed (most) monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 04, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or...
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Oct 02, 2009 | Microtek C783GM 17" Flat Panel LCD Monitor
Dialogue box in the middle of the screen
Out of range usually means that the computer is trying to use a resolution that is unsupported by the monitor. Try loading the PC in safe mode (for windows, press F8 before windows loads) and change the desktop resolution to 800x600, which is supported by pretty much any monitor. Restart the computer normally and you should get your video. Once inside windows you can experiment with different resolutions, and when it goes out of range, just wait 15 seconds for it to go back to 800x600.
May 15, 2009 | Microtek 710S 17" Flat Panel LCD Monitor
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
Increasing resolution higher than 800x600
the screen res is adjusted through windows not through the monitor.the pop up you speak of is only informing you the current screen res as set up through windows.
Dec 15, 2007 | ViewSonic VA721 17" LCD Monitor
Microtek 710S 17" Flat Panel LCD Monitor Logo
100 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
solver2010
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
