Question about Moen 7910 Chateau Two-Handle Kitchen Faucet with Side Spray Chrome...
Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It looked wet above the nut. Where is the leak coming from?
  • 490 Answers
The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
Posted on Aug 22, 2010
Testimonial: "Thanks a lot, farmerbear. I think it was leaking when the faucet was off, so it's probably the cap I used. Remove it and seal better; I'll try it! "
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    HOW TO CONNECT DISH SPRAY
    My first question is it a moen factory dish spray hose for that model? If not and it is a universal type it might not work at all on the moen. If it is a true replacement part then check the threads both on the faucet body and on the hose end to make sure they are not damaged or cross threaded. If the original hose was put in and cross threaded the connection on the faucet body the new hose will probably not screw on. If this is a quick disconnect model make sure that the faucet body connection is clean and place a small amount of faucet lube on the hose connection to help with installation. Sometimes what might happen when replacing a quick connect end is the old hose left bits of O-ring in the faucet connection which will not allow the new end to seat properly.
    Aug 29, 2014 | Moen 7560BL Extensa Matte Black Lever...
    I am having a leak with the hydrolock going to the sprayer hose on a new Moen faucet. I have taken it apart a few times to make sure it's together right, but I can't get it to stop leaking.
    Three years ago, I installed a Moen kitchen faucet with sprayer
    in one of my rental units. Moen twice sent replacement
    Hydrolock kits, as I couldn't get them to seal. While waiting for the Moen parts to arrive, I used a short length of heater hose purchased at AutoZone, held on by two small hose clamps. After all three Hydrolocks had failed to seal, I just left the heater hose in place. Three years and no problems. ..and no more Moens, either.
    Sep 16, 2011 | Moen 87530 Touch Control Single Handle...
    Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
    If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
    Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Handle won't stay up
    I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
    Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    Moen kitchen faucet leak from spray
    This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
    Feb 23, 2010 | Moen ShowHouse S711 Waterhill Single...
    I am reinstalling a Moen 7345 riser faucet in my laundry room. This faucet was removed from a bar sink two years ago by the contractor who replaced my kitchen counters and changed my two kitchen sink...
    I had a similar problem and, like you, found that there was nothing for the washer to seat against. Apparently, there was a metal bushing installed when manufactured, that was entirely eaten away by electrolytic corrosion - mine took nearly twenty years. I machined a new non-metallic bushing, installed it, and the problem was solved.
    I also sent Moen's president a letter explaining the problem and how to fix it but heard nothing back from them. At the time, no parts were offered that could fix the problem.
    Jan 30, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    I have a moen pull out kitchen faucet that leaks
    You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
    Aug 30, 2009 | Moen 87555C Trianna Single Handle Pulldown...
    Moen 7910 Chateau Two-Handle Kitchen Faucet with Side Spray Chrome... Logo
    213 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
