Question about MTX Thunder 8302 Car Audio Amplifier
Cant figure out my car audio problems!!!!!
Just re-installed my MTX thunder 8302, and rockford p2..HELP!!!?
Ok, So ive had my system for years,in a couple of different cars. I originally had a rockford punch amp, and a earthquake 10 inch sub in my focus, blew the earthquake sub, went out and bought a rockford p2, worked great. One day my head unit cut out, and i blew my fuse for the headunit(faulty wiring). Replaced fuse, and got the hu working, sub and amp came on, but no signal coming throught the sub. Then bought my mtx amp,thinking it was an amp problem hooked it up, turns on, but still no signal. I then was told by crutchfield, that they would recommend a 4g wiring kit(which i only had an 8) Just rewired the whole car with a scoshe 4g complete kit(rcas,ground,power,remote,etc), amp still comes on, but still no signal through the sub. I checked the sub, by hooking up to my home stereo, and did the battery test to the terminals..sub seems good. Could it be my HU's rcas are blown?Just checked all of my wires, even had another head unit, hooked that up, still nothing, only a faint,rumbling from the sub(not to the music)
  • 631 Answers
There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
RCA shield ground test
You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
Posted on May 04, 2008
Red light is on but nothing coming out of the amp
Capital Audio Repair -Tallahassee,Fl 850-339-1130 we repair all namebrands & all models
Mar 16, 2010 | MTX Thunder 8302 Car Audio Amplifier
MTX 8302 sound just quit on front speakers
hi Dan....Have you had any other service or installs shortly prior to the onset of clipping? In any case, the 8302 has Onboard Thermal Protection which is kicking in due to excessive heat. If you've had this running fine for a period of time, by that I mean at least a month, then we need to focus on why you're suddenly overheating......please update your post with any further information and progress.....good luck my friend
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
It turns on but my music wont come out
I had this same amp and the rca inputs went out. If i wiggled the rca plugs sound would come out but when i let it go the sound stopped so see if the rca inputs move at all because they are not suppose to
Jul 06, 2009 | MTX Thunder 8302 Car Audio Amplifier
Low output from T8302 MTX Thunder AMP
It sounds like an Ic is to blame, Check individual channels to find which one is not working?
Jun 11, 2009 | MTX Thunder 8302 Car Audio Amplifier
MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Jun 03, 2009 | MTX Thunder 421D Car Audio Amplifier
Feedback issues.
Did you run your power and remote wires the same route as your RCA cables? If you dont run the RCA cables on the opposite side of the power and remote you will get feedback through your speakers. I run my power on the side closest to the battery along with the remote ( passenger in my case) and the RCA cables should be on the opposite side( driver side). They say the power current will create a disturbance in the RCA cables that you would hear as feedback. Hopefully this will help you.
May 28, 2009 | MTX Thunder 8302 Car Audio Amplifier
Tuning 8302 amp
The amount of power that youre going to run on those 5.25s might indicate that you need to turn the crossover to a higher cutoff frequency because they gonna want to kick pretty hard if your set too low - Sounds like you got it under control though flip it to high-pass(HP) and see how it does at around 100 HZ cutoff- be sure to turn off any bass boost on the amp though too- Let me know how them soundstream mids do- I have a set of subs that kick *** but i never have heard anything about their mids-good luck
Oct 18, 2008 | MTX Thunder 8302 Car Audio Amplifier
Did u figure out ur problem
What sort of problem are you having?
Jul 24, 2008 | MTX Thunder 8302 Car Audio Amplifier
Audiobahn A 18001DT
the remote of amp. is not a ground it is a pos.+ 12 vlts look the back of your car stereo red the remote and conect to remote of the amp. if no sign remote of the car stereo conect to the 12 vlts of your bat.
Sep 18, 2007 | MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
MTX Thunder 8302 Car Audio Amplifier Logo
160 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
hoyzee1
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
