Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
It wont turn on. It is getting power but stops after 10 seconds. Tried the red reset button but still wont work. Pls. help! Thanks!
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Posted on Oct 22, 2010
Lenovo idea pad 300 won't turn on. Red power light blinks 3times then switches off. Rebooting doesn't work. Tried different adapter. Power on Lenovo screen appears for 5 seconds then goes black.
Sometimes they 'crash' in sleep mode. Try hold the power button down for 10 seconds. This should make it reset. After the 10 seconds, release the power button. Then press it again to turn it on normally.
Oct 09, 2017 | Lenovo Computers & Internet
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
I have erased all setting and content after then its not working
Sorry to read about your problem, I hope this helps you out.
you will need to restore the iphone via itunes, on your pc
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Apple iPhone 3G
How can I make a permanent fix to the waste ink reset? The problem started with three solid red lights on display panel from L to R when giving the printer a job to print out. I have tried one fix...
Have you tried cleaning them?
Found this on web helpful. If you find this helpful, pls rate me.,,,,,,,,
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
Thanks and Good Luck :0)
Jan 29, 2010 | Epson Stylus 880 InkJet Color Printer
Wireless stopped working. If correctly plugged
Have you tried a hard reset, then setting up the wireless again?
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 10, 2009 | Computers & Internet
Iphone will not turn on
Here are the steps to reset the iPhone. You probably performed the first reset, try the other resets.:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Thanks, Joe
Jun 30, 2009 | Apple iPhone Cell Phones
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
I change settings
The reset on my son's CH-DVD 300 was the stop button. All i did was turn on the dvd player and then held in the stop button for 10 seconds. And badow, I have video.
Nov 28, 2006 | Cyberhome CH-DVD 300 DVD Player
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
104 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
