Question about Kitchen Ranges
Since replacing the light globe, my merlin powerlift 2500L won't stay down. It goes down albeit much slower response to pressing remote, but won't stay down! What do I need to do??
Merlin powerlift 2500l
Check your own remotes ! If you have an extra in a junk draw every time you open and close the draw you can possibly have something bump up against one of the buttons and with their sensitive buttons they can easily be triggered.....I had a customer that was happening to her . Another situation could be leaving a remote in a pocket or purse ...again these buttons don,t need much to send a signal to your opener without you even realizing it! Another situation I have seen is a neighbor having the same age machine as you ..the frequency transmitting signal has changed over the years because of interference from other remotes or microphone signals such as police radio,s ..ambulance...fire stations all use these frequencys , also local airports and private planes all transmit these signals ...even your neighbors remotes were a problem until they came up with rolling code technology , if you have this then you should not have any interference from any outside signals and you probably have a remte laying around that's getting bumped ! If you and a neighbor have similar machines from earlier then 1985 then you probably have a garage door opener with dip switch technology ....On the dip switch settings you have to set your own code but most people had them installed straight out of the box without any code changing and left the factory settings to 0....Well most likely your neighbor also did not change from the factory settings and that can be another scenario....These are all things I have seen as a garage door mechanic and could be possible scenario,s for troubleshooting your problem , Hope I was able to help you but if all else fails then definetly go with a new receiver kit because it would definetly have rolling code technology
Apr 12, 2014 | Building Materials
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
I have a Merlin Powerlift 2500L that opens and stops half way. When disconnected from the door, the release rod travels the proper distance. However, when the door is connected, its upward movement stops...
Release the door from the opener and operate it by hand. Check for binding and excess heaviness of door. You may also need to increase the up force. Heaven only knows where it is on a Merlin.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Can I get a replacement remote control for a Merlin Powerlift roller door model 2500L 1/3 horsepower
Check out this site.
http://www.retro-remotes.com/apps/webstore/products/category/365891
Apr 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Where can i buy a remote to suit a merlin 2500l elect garage tilt a door. thanks,bruce sydney nsw
Go to this website mate.
http://www.chamberlainanz.com/index.php?option=com_content&task=section&id=4&Itemid=81
Mar 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin powerlift-model 2500L Garage door and cannot find the Learn Button to program my new remote. Please help...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need the codes to program my Innovage Jumbo Universal Remote for Dynex television
As there are no specific codes for the Dynex TV you have the choice of either using the Auto or Learn method. The following are instructions for both:
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. *
Mar 02, 2010 | RCA RCU600M Remote Control
Kitchen Ranges Logo
169 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
