Question about Garmin Nuvi 660 GPS Receiver
How do i reset the 650? The touch screen isn"t responding
  • 35 Answers
First you need to disconnect it from external power, then flip up the antenna to see the reset button. Press the reset button. Then reconnect it to external power, it should turn on automatically and work normally.
Posted on Aug 22, 2010
How I fix it?
If the screen does not come on that is a serious issue--if it comes on but does not respond it is possible there is a reset for the unit--get in touch with the model number with Garmin---many of the GPS makers have a flat fee for a unit if it needs repairs---weigh the cost of repair versus the cost of replacement of the unit.
Jun 14, 2012 | Garmin nuvi 650 GPS Receiver
My iphone 3Gs touch pad isn't responding. Tried restarting by holding down sleep and home button till apple logo appreared, yet, iphone isn;t responding.
the touch pad of iphone 3gs is given a problem.tried to reset it..but wen general option comes up and we have to choose the reset option,cannot scroll down to get the option..what to do??
Nov 29, 2010 | Apple iPhone Smartphone
Garmin 650 comes on when powered up but touch screen does not respond. Have tried to reset instructions and that does not help. Any suggestions?
I had the same problem, but I had to change battery in my unit. I read a post that suggested I take a business card between the touchscreen
Oct 19, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen not functioning
Please see this link. Most likely uou have one of the newer SHARP touchscreens that is known to fail prematurely.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Dec 15, 2009 | Garmin nuvi 650 GPS Receiver
My touch screen isn't working and won't respond
try to reset the equipment . See in the bottom a small buttom and push it.
Aug 14, 2009 | Garmin nuvi 650 GPS Receiver
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Try to find how to calibrate the touch screen in the users manual.
May 29, 2009 | Garmin nuvi 250W GPS Receiver
Screen orientation
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Vx.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Nov 08, 2007 | Computers & Internet
Screen orientation
Oct 28, 2007 | Palm Vx Handheld
Garmin Nuvi 660 GPS Receiver Logo
112 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
