Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
17 inch flat screen monitor has trouble turning on
When I turn on the system the little light on the bottom right of the monitor constantly alternates from red to blue. It should just be red if no signal is being transmitted from the PC. When the computer boots up the light just slowly blinks blue but no image appears. If you fiddle with it long enough (rebooting the computer, plugging and unplugging the cable from the PC, etc.) you can usually get the monitor to display an image. I haven't figured out exactly what combinaton works or if getting it to work is just a matter of luck. The monitor acts up the same way on two different computers.
  • 2 more comments
  • Lostntransit May 04, 2008
    P S The monitor is a Spectre X7G-NAGA VI
  • Lostntransit May 05, 2008
    I changed the video output to 60 Hz, but it didn't make any difference.
  • Lostntransit May 06, 2008
    After reading various reports on this model I've come to the
    realization that what I have is an expensive paperweight with a red and
    blue blinking light on it.
  • refriedbeans Nov 20, 2008
    I have the same monitor and same problem. I find that if I Press F8 on startup and select which Operating System I want to boot to the monitor will come on. but from a standard power on with power button I get blinking light no screen.
Make sure that the PC video output is set at 60 Hz. The LCD often will accept up to 75Hz but will not work correctly.
Posted on May 04, 2008
My syncmaster 730MW used to take some mins before coming on..then it got to an hour, now it gone of completely what do i do?
> what do I do ?
Spend $50 to $100 at any TV/video repair-shop, for trouble-shooting and repair.
Or, spend $40 to $50 to buy a used 17-inch LCD screen, or $100 to buy a new 19-inch LCD screen.
Feb 17, 2011 | Samsung SyncMaster 730MW 17" Flat Panel...
When turned off for the night, it takes forever for monitor to turn on, the lights on the power button constantly change colors before the screen will work. Is this computer or monitor related?
Maybe your monitor's having trouble getting power. Try plugging it out, and then in again. If that's not working, call you're monitor's manufacturer (if you don't know the number, try searching on the internet). Or maybe that's not the case. Maybe your PC takes time sending the signal to monitor. Call the computer's manufacturer (if you don't know the number, try searching on the internet). Hope that helps,
Daniel
Jun 18, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
Large black line at the bottom of the desktop - about one inch wide. Windows opens above the frame of the desktop.
you need to change the aspect ratio or position of the screen using the menu and buttons on the monitor
Oct 30, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Screen will light up for about 02 seconds and disappear.
The most likely cause is the power supply. This can be replaced by an experienced repairman. In Australia a replacement power supply costs around A$60plus labour.
Sep 22, 2009 | Philips 17" - Flat CRT Shadow Mask -...
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Plug and play PL716s proview monitor
after almost two/ three years my monitor is starting to give me trouble its comes on then it blinks off I have to constantly turn the power button on and off I cannot keep it on. Please help.
Jun 19, 2008 | Envision EN-7220 17" Flat Panel LCD...
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
"BLANK SCREEN, CLICKING SOUND, & NO LED INDICATED".
some electronic components on the circuit was shorted.
clicking indicates this type of problems.
Dec 03, 2007 | Compaq FS7600 17" Flat Glass Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
178 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
