I have a GE Profile WPRE6100G washing machine. It will not agitate or spin. I have attempted to reset the machine...no luck yet. The LED indicator light on the system board flashes normally.
  • cul8ertx Aug 22, 2010
    OK, I finally got the machine to reset the system board to flash codes for me. It flashes 6 times (locked rotor error) but nothing is stuck. The basket rotates freely by hand as does the pulley, motor shaft, etc. I put the washer into field service mode and it has the same issue (no go) when cycling through the agitate and spin test modes. So now I'm thinking motor/inverter replacement. If it were simply a fuse, would the system board light up at all?
    Champion:
  • 245 Answers
There is a fuse under the top cabinet running down to the motor. It is small it looks like a shrink wrap around a white wire I think. When It goes bad this is one symptom. The next thing could be your lid switch. I would check your lid switch first. GE's are tricky.
Posted on Aug 22, 2010
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
Washer will not agitate or spin
belt could be broken. If not try unplugging for two minutes, then plug back in and open and close lid seven times slowly to reset computer than runs machine.
Aug 15, 2009 | GE Profile WPRE6100G Top Load Washer
Wash machine will fill but not agitate or spin
Check the lid switch. GE will not go beyond fill with the lid pen and if the switch fails the machine thinks the lid is up. Eric
Aug 08, 2009 | GE Profile WPRE6100G Top Load Washer
Washer does not agitate. Will spin and drain.
bad dogs pull off center cap remove bolt carefully lift off dogs are two pieces that catch to agitate they are minimal cost and are easy to replace they wear out especially with heavy loads!!!Best of Luck to You!!
Jun 28, 2009 | GE Profile WPRE6100G Top Load Washer
Will not spin or agitate but does drain
Lid switch? Does motor run? If so check belt.
Jun 23, 2009 | GE Profile WPRE6100G Top Load Washer
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Sep 20, 2008 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
