Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
I had my system serviced a few days ago (Salt Water pool) I noticed the last 2 days that the spa fountain is running continuesly and that the pool and spa lights won't turn on. I just noticed that the RS4 panel in thge house had a red light on Filter Pump. The panel is readdin Service mode is active. What do I do?
  • 905 Answers
Is it possible that the service tech left your controller in service mode for a particular reason? Start there, there may have been something forgotten during the visit. I suspect that you are under a service agreement for your pool, and the contractor has exclusive at the moment.
Posted on Aug 22, 2010
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
I have a 13X42 inch Metal Frame Pool and we have added over 55 lbs of salt to our pool and its still green and saying low salt.... what should we do and how much salt does out pool actually need??
You need to get water tested then add the right amount of shock + others and check in a few days to see where the water is at. The salt system only keeps pool right when in balance.
May 29, 2011 | Intex Automatic Salt Water System for ...
We changed our pool over to salt water four days ago ago and it is cloudy and has green algae in it. It had green algae when we switched. We thought the salt water system would kill it, but it is still...
You don't mention the size of the pool. If this is a above ground small pool ... dump the water, clean the liner and refill it. Remove the metal with a sequestering agent. Get the alkalinity correct. Get the pH correct then add the salt to 3200 ppm.
Chlorine kills algae. Are you sure it is algae and not metal in the water?
pH should be 7.2 to 7.6. Alkalinity should be 100. If a gunnite pool, the calcium should be 300. Salt should be 3200. Cyanuratic acid should be 50+ if this pool is outside (not indoors).
What to do. If this is a big pool, and you are sure this is not metal in the water, I would super chlorinate the pool - take it to 20 or so ppm. Run the filter for at least 24 hours. Watch the pressure ... you will be filtering out a lot of stuff.
Let me know what happens ...
Thanks for your question @ FixYa.com
May 24, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
I purchased an INtex 9 x 18 Rectangular Pool less than a month ago. Th "all in one system" works fine when you select the "FP" (Filter Pump) cycle. However when you switch to the "salt water system" cycle...
Service light is not fixable by the consumer
you will need to call intex
they will e-mail you a form fill it out and fax it back to them
you will have a new pump in a few days to your door
it must be under 2 years old and you must have a valid receipt
I just bought a saltwater system for my 12x39 pool a month ago did start up like book said and pool was fine for a month then the low salt light came on so i put 15 lbs of salt in per instructions kids...
you really should get test strips for salt. Get the kind that reads #'s
Get your pool to as close to 3000ppm as you can. any lower than 27000 and you do not generate enough chlorine any higher than 3600 will taste bad and could trigger high salt alarm 3000 is best
run filter only for a few hours before running generator the salt needs enough time to fully distribute through the pool
Jun 30, 2010 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy after 2 days
DID YOU USE POOL SALT, MINE STAYED CLOUDY FOR 2 WEEKS AND FINALLY CLEARED UP , I USED THE WRONG SALT , 25LB BAGS OF TABLE SALT FROM SAMS CLUB
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
80 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
