Question about Dishwashers
Load water but doesnt wash - Dishwashers
  • 36 Answers
Well what kind of dishwasher is it? ( make and model)
Posted on Aug 22, 2010
Water doesnt stop when filling washing machine
There should be a "fill control" on the panel of the achine that lets you set the fill limit for wash loads ranging from small to large. Obviously, your fill control is not working
Oct 09, 2012 | Washing Machines
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
How do you stop the cycle immediately after starting (found a sock that needs to be added in the washer) and then re-start wash cycle
You can only add items to the wash for a few minutes after that washer starts. If you found something you want to add you have to restart the cycle. This is a safety feature added to the front load. After the washer is full of water it doesnt allow the door to open so the water in the machine doesnt flood you laundry room.
Jul 15, 2011 | Asko W6021 Front Load Washer
Drains water but doesnt go into spin cycle
heatman101
Oct 01, 2010 | GE WSXH208A Front Load Washer
Wont spin,and the water doesnt drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
The water is on but the water doesnt fill the washer. the spin cycle works how do i get the water to fill the washer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | Maytag MAV8557 Top Load Washer
Indecit W123 washing machine water doesnt heat. The water doesnt heat up in my machine.
More than likely that the heater element has failed,
This is usually located at the rear of the washer, remove rear panel, and test with a meter, this is the only sure way of testing it to see if it is o/k.
Mar 17, 2010 | Indesit W 123 Front Load Washer
Washer will go thru the wash but always stops at
ck the cold water is on / ck the water valve . this would stop it in cycle . it can't get rinse water . maybe pc control but unlikley.mm
Dec 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Ideset front load washer
If no water is entering the drum, and it is not leaking out anywere, then there can be no water coming in at all, unless the pump is coming on right away and pumping the water out., check the waste outlet pipe as it is filling, and see if water is discharging from hose
One other possibility is that the belt is off and the whining niose is the motor turning on it's own with out turning the drum.
This being the case, u probably wouldn't see any water in the drum, due to the small amount that they take in.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
Open Questions:
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
