Question about GPS
Unable to acquire satellites - GPS
  • 12 more comments
  • eneasg May 11, 2008
    My Garmin Nuvi 660 Cant read the satellite
  • Anonymous Jun 08, 2008
    unable to acquire satellite
  • mimibailey Jun 09, 2008
    Unable to acquire satellites.
  • help for MD Jun 12, 2008
    Help! Last 2 days I am not getting a satelite receptionj- asking if I am inside, in my current state and the date. How do I fix this?
  • Anonymous Jun 14, 2008
    Nuvi 660 has a problem about satilite help
  • nsx1 Jun 14, 2008
    Nuvi 660 operated fine for a couple months, then started having satellite reception problems. Updated to the latest software, but still no improvement.
  • King Spyda Jun 16, 2008
    my Garmin Nuvi has been acquiring the satellite for two weeks....It is a joke!!!
  • Anonymous Jun 19, 2008
    Same issue out of box. Acqiured for a second. Then will not acquire at all.
  • Anonymous Jun 21, 2008
    Garmin 660 not acquiring satellites.  Updated software, tried reset still not working
  • Anonymous Jun 29, 2008
    Hi
    Have same issue contacted Garmin got it working again only to have it fail on the next trip only 10 min. after leaving home.
  • lazam98 Jul 04, 2008
    TRIED EVERYTHING BUT MY 660 STILL DOES NOT GET SATELLITES.
  • Anonymous Jul 12, 2008
    Same problem!
  • Anonymous Aug 12, 2008
    gpsmap 296
    quit receiving satellites during a flight
    switched antennae but still not reception
    switched off pulled batteries, cleaned connections
    no idea what to do
  • THIELDEMO Dec 28, 2008
    I HAVE THE GARMIN 296. WHEN TURNED ON COMES UP WITH "POOR SATELLITE RECEPTION" I REMOVED BATTERIES, REISTALLED AND HAS SAME PROBLEM. TIMT210M&AOL
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My Gamin Nuvi 660 Solution
External antenna - Garmin 25MCX low profile remote GPS antenna
I have been experiencing the same problem many have been having with the Nuvi 6xx and 3xx series giving an error message “Lost satellite reception”.
My problem started mid April 2008 and got progressively worse. I would use my GPS on weekends and it would work perfectly for the first 10 – 30 minutes and then would loose satellite reception, rendering it useless.
I bought my Nuvi 660 when it first came out in October 2006 for just under $700 and is now out of the 1 year warrantee.
I called Garmin Technical Support and we checked my Software version (4.40) and more importantly my GPS SW version (3.00). According to the tech I had on the phone, the GPS SW version was more important then the Software version. It was in fact already updated to 3.00, I did master reset, after master reset, but regardless, nothing helped.
I contemplated what I should do.
Return mine and get a refurbished unit from Garmin for $225 with only a 90 day warrantee?
Buy a new Nuvi 660 for around $300
Buy a new Nuvi 2xx series with fewer features for $200 to $275.
Buy a Megellian GPS?
I read through this forum and came across one person that was told by Garmin “that they are aware of an issue with some Nuvis involving the failure of a diode in the unit that senses whether or not an external antenna is connected.” Apparently this diode failure is caused from the high heat these units experience from being left in a hot car for long periods of time. This would explain why mine would work in the beginning and then die.
So my thinking was, if the diode “thinks” there is an external antenna attached when it isn’t, what would happen if I “did” connect an external antenna?
Garmin recommends the Garmin GA 25MCX low profile remote GPS antenna for the Nuvi 660 and costs $31.49 (not sure about additional costs for tax and shipping)
So I purchased the NEW antenna from a seller on eBay for $25.90 total and IT WORK FLAWLESSLY.
Just to make sure it really was the new external antenna that was working and not the unit coming back to life, I started my 3 hour journey with the external antenna NOT connected. As usual it lost satellite reception in about 15 minutes. I plugged in the GA 25MCX and it immediately connected to the satellites and never lost them.
I repeated the same process coming home and once again, I connecting the external antenna after the unit reported loosing satellite reception, and it worked perfectly.
Conclusion: if your unit is experiencing loosing satellite reception, and is under warrantee, return it ASAP. If it’s out of warrantee, get an external antenna. There are other manufactures of external antennas and all should work as long as it has an MCX connector.
Side Note: This external antenna also worked perfectly on a friend’s Nuvi 350 with the same problem.
I wanted to share this with everyone because I’ve been racking my brain for months over this. I hope this helps.
Posted on Jul 16, 2008
O.k. solution #2 work inmediatly garmin 296, thanks.
Posted on Sep 07, 2008
  • GPS Master
  • 2,130 Answers
Read more about this problem here:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Mar 10, 2010
I have a Garmin 60CS. Solution #2 worked for me. Many thanks
Posted on Jan 03, 2010
For Garmin 296 I had same problem. On another board it said Garmin support said to hold "out" button while turning the system on and to continue holding the "out" button until the unit say "I Agree." I tried it. The unit immediately displayed a different satellite sky configuration and locked onto about 10 satellites within 5 minutes. Based in this, there's probably some simple method for other GPS units as well, but only Garmin could tell you that.
Posted on Sep 01, 2008
I'm having the same issue in North Carolina, very frustaiting and dangerouse. I was driving ou by Camp Lejuene and lost everything....it took a while but I got back to Charlotte, this sucks. Garmin's Website to support won't load either. Does anoyone have the number?
Posted on Jun 16, 2008
Unable to acquire satellites with my garmin forerunner 305. a couple of guys using their 305s were able to quickly acquire.
I find my Garmin 305 is a slug to locate and lock on. But if I pull it off the charger just before I go for a run it locks on all most immediately. Give it a try and let me know if it works.
Jan 19, 2010 | Garmin Forerunner 305 GPS Receiver
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
Slow on picking up satelite on nuvi 260w
Good Luck. Did this help?
Dec 03, 2009 | Garmin nuvi 205W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Unable to get satellite reception
Make sure you are not moving and that you are on an open field with minimal aerial hindrances. It takes time for the GPS unit to acquire satellite signal and makes it difficult to acquire when you are moving so make sure you stop at an open are till it syncs with at least 3 satellites.
hope this helps!
-levibit-
Mar 20, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Satellite unacquireable.
never buy magellan there junk lol and the problem you are having is a broken flip out antenna on the back of your unit ..it is common with the older flip antennas just buy a external antenna from garmin and fixed .......if not send it back to garmin because its hardware is bad
Aug 23, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
2,838 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
