My sony MHC-RV2 is not reading DISCs.. showing TOC reading always..
SOURCE: TOC ERROR ON DENON DN-C615
Take this info with a grain of salt. I recently received one of these units with a TOC error, and after removing the drive assembly and reinstalling it, the problem went away. Before removal, I observed the motor spinning poorly and even backwards. Rather than pull the whole drive assembly, I would first eject the drive and remove the face from the tray. This is done by putting your thumbs on the tray and pulling up with your pointer fingers underneath the face. It should just snap off and snap back on the same way. Try playing a disc now, if it works try loosening the screws on the drive assembly and shifting the assembly towards the front of the unit, tighten the screws and put the face back on. You should be good to go. There are four screws holding the assembly down, the two in the back can only be accessed when the tray is in the open position. The front two are accessible through holes in the tray, and I don't recall if the tray has to be open or not, but that's easily observable. If it's still not working, there is a flat-flex cable running to the laser assembly. Pull and reseat this gently. Try to only manipulate the cable by the blue reinforcement tab. I hope this helps!
Posted on Nov 30, 2008
SOURCE: sony mhc-rg330
Get a lens Cleaning Disk and put it into the CD Player, there could be foreign objects on the lens itself, these and other shelf systems all have one common problem... Dust.
jon
Posted on Aug 12, 2009
ETRONIC
  • 62 Answers
SOURCE: sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Posted on Feb 16, 2010
caroldon
  • 17130 Answers
SOURCE: sony mini hifi MHC w28d showing reading but no
You player is not detecting the data stored in the disc. this is due to many issues, but firstly let us first clean the optical head either using a lenns cleaner- good one- or by using a good sway gently on the lens.it this wont work, open the system and check the drives. if the cd rotates but fails to read you have a defective/ weak optical system. you will need to replace the head. Further if you can check for the RF in the optical, absence means failure. Also the main board/ processor could be defective. All this can idicate the same fault of no reading / playing. However if the reading is seen but there is no output then check for the speaker outputs/ speakers. check for audio out for signals. if present then the output audio amplifier is defective. check this out. Good day.
Posted on Jul 12, 2010
Obertelli
  • 3006 Answers
SOURCE: sony cmt-cp33md,place dic in machine,toc
The c13 error means that the player is unable to read the table of contents (TOC) on discs any more. If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your player, but I hope that my reply has given you a practical alternative means of solving your problem.
Posted on Oct 07, 2010
Testimonial: "Many thanks,although it's probably not what I wanted to hear"
Troubleshooting cd player
Your Optical Pickup is worn out. When you put the disc in the drawer, it must load to read the TOC(table of contents). If it can't read the TOC, it will stop or eject.
Aug 17, 2014 | Technics SL-MC3 61-Disc CD Changer
Sony mdmx4
The recorder cannot read the table of contents on the disc.
You may have a bad disc but I think the disc might have been recorded on another MD deck which may have a different extended format recorded on the disc. Sony over time offered a lof of different recording options and some of their decks can read some of them while others cannot.
I'd check your player with another disc to see if this is the one disc you mention or all discs. if it is all discs the recorder has a problem due to a dirty laser or damaged head so it cannot read the table of contents.
Mar 26, 2014 | Audio Players & Recorders
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
My SONY MHC GNZ 7D shows please wait in the DVD position.Other functions such as Tape,FM Tuner etc are working fine .Please help.Question from N.Shankar
Hello
Check it with an MP3 disc and a viedo disc. Cehck both of them are reading well and OK. Check with new CDs. If these discs works on and the problem occurs only with DVD discs, check it with other DVD discs. Some writion formats may not recogonized by the set. If the problem occurs with all discs, just put in a lens cleaning disc into the player, and pley it at least three times. This disc can be bought from most of the electronic spare parts at your town. If after cleaning, the problem perists, the Laser Pickup Unit should be replaced with same type and number. If you are experienced to disassemble and reassemble the CD mechanism, you can do it by yourself at home. It is a skilled work. If you are not experienced, get this set repaired either by Sony Authorised Service Center or by any well experienced service techinican you know well. OK.
Jan 18, 2012 | Sony Audio Players & Recorders
Sony cmt-cp33md,place dic in machine,toc reading shows read error C13,then ejects disc.
Sep 06, 2010 | Sony CMT-CP33MD CD Shelf System
I have a problem with my MD player.on screen showing read error c13.is it easy to fix?
The error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
Mar 16, 2010 | Sony CMT-M100MD\W CD Shelf System
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
43 people viewed this question
 Grubhead
Grubhead
