Question about Panasonic Viera TH-42PZ85U 42 in. Plasma TV
Panasonic TH-37PX50U. LED power light blinks 20 times then pauses. TV is stuck on the HDMI input. Can't change to TV or Video inputs.
  • 61 Answers
SOURCE: Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Posted on Oct 09, 2008
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
SOURCE: Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
Hi, Would you buy a used panasonic TH-37PX50U?
Must check tv carefully for tv images burn in problems,plasma tv have that problems alot.This tv have major issues are power shutdown alot and power supply will not sustance and flashes it power light indcation.Have to unplug awhile like an hour replug back to get tv to work again.If u have chance to used it like 5 hour a day like for a week have warrenty for a week for a return it and get 95% of ur money back.Used it for a week about 5 hrs every day no power shutdown and no power LED light indication flashes i whould buy it.
Aug 28, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Sep 08, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic Plasma HDTV 50" Viera--won't turn on. Red light flashes 10 times followed by a 3 sec pause, then repeat 10 flashes. Have solved problem by unplugging it and plugging it back in, but that is not...
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video devices, Blu-ray Disc Player, DVD Recorder, etc.
The front or side HDMI inputs only are designated for PC. To use the TV as a PC monitor, advise customers to use only front or side HDMI inputs.
Jun 16, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Mar 12, 2009 | Panasonic Televison & Video
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Dec 30, 2008 | Panasonic TH-42PX60U Television
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Power light blinks 10 times
You have the same problem i have. My Tv just did the same thing 3 nights ago. I unplugged the set, and let it sit ofr about 6 hours, and then tried it again. It turned on and played, but repeated the problem after about 20 or 30 minutes. So far all my research has led me to believe that its a power supply issue. Problem is, there are 5 boards in the tv with seperate pwer supplies, and the 10 red flashes indicate that its all of them. :-(. Im shopping for a new TV, and It wont be a panasonic this time.
Feb 24, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv will not turn on
Possible power supply panel faulty.
Feb 09, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
