Question about Epson Stylus C46 InkJet Printer
How can i use my epson stylus nx110 without the need of black ink to print stuff out??? Albert Rea
MerlinTech
  • 197 Answers
SOURCE: Black ink not printing...
same on a test page?
Posted on Jun 16, 2008
don_farr
  • 1018 Answers
SOURCE: how can i use epson stylus c45 without black ink
If this is a color printer, then you cannot use it without the "Black" cartridge.
Most printer manufacturers will pull from the "Black" ink to print black on color images. They do this to save on creating a "processed black" from the color inks.
Just curious, are you using a "CMYK" system? (Cyan, Magenta,Yellow and Black inks)
Don
Posted on Nov 02, 2009
SOURCE: The black ink will not print on my Epson Stylus
I have an Epson sx600fw which has had a problem printing with black ink. I spent alot of money trying genuine and cheap inks as official advice is to replace with a genuine epson cartridge and clean up to 6 times before seeking further help. Tried this to no avail. By accident I found that if you set the paper type to glossy or photo then miraculously the black will work but in this setting it is slow. Epson replace the printer under warranty but I have just received a new one and it has exactly the same problem. I am slightly reluctant to buy another set of genuine inks to waste through 6 cleaning cycles as they are over £35 so am not sure what to do but I guess I will approach Epson again.
Posted on Nov 05, 2009
cns assoc
  • 677 Answers
SOURCE: I REPLACED MY INK IN THE EPSON NX110 PRINTER
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if any of the cartridges are empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 01, 2010
SOURCE: Have an epson stylus nx110 printer and have to
Find the NX110 in the printers section of the control panel. Then right click your printer and choose "Printing Preferences" then the "Maintenance" tab. In there you will see a button for 'Replace ink cartrige'. Select that and it will take you through it step by step and even move the print heads to the correct position so you can change the ink.
Posted on Mar 18, 2010
My epson stylus NX110 is printing blank pages
Printer heads clogged or cartridges are empty or defective.
Feb 10, 2014 | Epson stylus nx110 All-In-One InkJet...
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
Have an epson stylus nx110 printer and have to replace ink cartridge. the cartridge holder will not go into place so that i have access
Mar 13, 2010 | Epson Stylus NX400 InkJet Printer
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
How to change ink cartridge in epsonnx110
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
130 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
