Question about RCA Televison & Video
When im watching tv, the menu will pop up allby itself. it then scrolles through the menu choosing different things.hoping you can help Darren
How to program a vizio tv without a remote vizio
Upon first start you should be prompted. If not, you will find a series of buttons on the TV itself; power,channel up down, volume up/down, input and menu. Hit the menu button and the menu will pop up. Scroll up and down with channel button, select and controls are the volume. either that or you can get a Samsung phone that has an app built into it called watch on, which has a universal remote that works for virtually everything. Happy surfing.
Mar 05, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tip
How to set/ change time on Polar F6.
Having trouble setting the time with your Polar F-Series watch, here is simple quick step-by-step guide to follow.
First know your buttons:
upper right - Scroll
lower right - Scroll
center right - choose
lower left - reverse/ back/ stop
upper left - light
#1 - Push the center right button (exercise will appear)
#2 - Push the upper right button (settings will appear) use the upper right or lower right buttons to scroll if neccessary
#3 - Push the center button (a menu will appear)
#4 - choose Watch, use the upper right or lower right buttons to scroll if neccessary
#5 - Push the center button to choose watch, once highlighted
#6 - use the upper right or lower right buttons to scroll through the watch menu
#7 - Choose Time
#8 - Continue to use center button and scroll buttons to choose and set.
Important button to know - the bottom left button is a reverse button. Make a mistake, just tap that button, keep tapping to go all the way back to the main menu.
on Dec 22, 2010 | Polar F6 Wrist Watch
I want to watch netflix on my proscan tv, but I've put the tv on every channel and netflix doesn't pop up
it could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
Nov 29, 2013 | Proscan Televison & Video
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
The vocal commentary for blind people has switched itself on. how do we switch it off?
It may depend on the model. Usually this is in the SAP options. It may be adjustable in the Quick Menu. Otherwise, enter the Menu > SAP (if an analog channel). Press Enter and then select SAP, Mono or Stereo and then press Exit.
If you are watching a digital source, then Menu > Multi Audio. Press Enter and then choose the language/content and then press Exit.
This is for the 32LD550. If you have a different TV, try LG's site: http://www.lg.com/us/tv-audio-video/televisions/index.jsp . The manuals are available for many of the TVs.
I hope this helps.
Jan 29, 2011 | LG Televison & Video
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
What I did
Remove back cover.
DONE.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Menu popping up
check the menu button on front panel(if available) if theres a sign of stock up.compare it to other button ch up ch down etc.this may cause the menu to pop up and disable all button even the remote control. but in rare case,the system control chip may be malfunctioning.hope this help u...
May 09, 2007 | Toshiba 32A43 32" TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
