Question about HTC G1
I can't hear incoming or out going calls on handset.can only hear on speaker.
  • HTC Master
  • 17,129 Answers
The ear piece can be weak defective or dirty, clean the panel to the earpiece and take away dirt with a thin pin. If the sound is not good check the earpiece with a tester, replace if bad.
Posted on Aug 22, 2010
I am trying to figure out why i cant hear any outgoing or incoming calls?
Hi
The handsets earpiece.Have it checked or probably replaced.
Thank you,
ken
Aug 02, 2012 | LG Chocolate Touch Smart 3G Cellphone &...
I cannot hear anysound (incoming calls, speaker or even rigingtones and music)
check if your speaker is fine.if yes then reinstall the phone software or go to lg care to change the speaker.check also if you get soung by plugging the headphones
Apr 03, 2012 | LG P500 Cell Phone
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Good luck from Headsets Direct!
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Calling party cannot here receiving party
This can be one of a couple of things. First of all, if this is a multi-handset phone, go off hook on two handsets at the same time and see if you can hear yourself in both phones (Speak into one while listening to the other) If it is only a single handset phone, do the same thing only with another phone. If you cannot hear anything coming from the uniden phone, it may have a bad mic in the handset and would need to be replaced. (the handset not the mic) If you bought it less then a year ago and still have the receipt, call uniden at 18002971023 and they will help you get it replaced.
Mar 22, 2009 | Uniden Cordless Phone
I have a problem with 6610i set that I can't able to hear other person's voice -
This sounds like the speaker in your handset which transmits sound to your ear is either faulty or turned down. Check the volume on your handset is set to max.
If the speaker in the handset is faulty - to trouble shoot this try using a handsfree kit which plugs in to the bottom of the phone and if the ear piece works correclty on a call through the handsfree eairpiece then your phone may have a fault.
Please dont forget to rate..
Jul 16, 2008 | Nokia 6610i Cellular Phone
You advice was such a blessing
Haven't experienced this one, it should open if you right click on the icon in the tray at the bottom.
However you should still be able to change your Skype options, click on "skype", then "Tools", then "Options", then "Audio Settings", change microphone and speakers to "logitech" or whatever your computer has listed your device as. This should have the effect of changing logitech to "use handset" and gets the same result. Unfortunately the phone will never work as good as it should, for instance I can't make test calls. I hope this helpful.
Jun 13, 2008 | Logitech Cordless Internet Handset Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Ringing problem
try via using another profile in settings...option is there...else restore ur handset.....if that silent mode does not remove then do flash upgration....speaker is fine if u r able to hear the incmoing call.
Aug 05, 2007 | Nokia 6610i Cellular Phone
HTC G1 Logo
169 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
