Question about Pride Mobility Products Pride Jazzy 600
Lights flash left to right .but know they stay on and will not turn off
  • rose324 Aug 24, 2010
    there is nothing wrong with the battery connections. installed two new batt. a week ago a long with two new motors. it was working just fine , untile it started flashing left to right and know it will not shut off, unless you disconnect the batterys. then it will stay off untile you turn it back on, and then it stays on untile you dicconnect the battery a gain.
    thank you rose@stickerwerx.com
  • rose324 Aug 25, 2010
    new batterys ,new motors, worked fine for one week then light started flassing left to right and know wont shut off.
    Top Expert:
  • Pride Mobili... Master
  • 80,417 Answers
Have the switch and the timer replaced for the signal lights.
Posted on Aug 25, 2010
    President:
  • 1,194 Answers
Visit this link for VSI controller's flash code, This will help you out in detecting problem with you power chair. I believe there is a problem with the battery connection as lights won't go off.
If you won't be able to resolve it then contact Pride Mobility 1-800-800-8586 (US) 1-888-570-1113 (Canada)
Good luck and have a nice day.
Posted on Aug 22, 2010
Flashing indicators on my audi a3 dont flash but stay on constant
change it. most likely contains the flasher for turn signal also
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Jun 03, 2014 | Audi A3 Cars & Trucks
My right turn signal isn't working correctly. When I'm driving down the road my dashboard indicator for my right turn signal will turn solid green but wont flash, But when i turn my...
I had the same problem on a 92 & 95 Dakota years ago, replaced the turn signal switch in the column & found a loose ground wire in the harness back by the tail lights. Never had a problem again. If you're gonna try to replace the switch you will need tamper proof torques bits just FYI. Good luck. Let us know how it turns out.
Nov 07, 2012 | 1995 Dodge Dakota
MY LEFT TURN SIGNAL ARROW INSIDE STAYS LIT WHEN THE CAR IS STARTED BUT DOES NOT FLASH.THE RIGHT FLASHES.THE LEFT TURN SIGNAL CLICKS ONCE THEN NOTHING BUT IF I MANUALLY PRESS DOWN IT FLASHES.
make sure all the turn lights are working on your car. sometimes this is an indication of a burnt out bulb. you likely need to replace the flasher relay under the dash. if you have trouble locating it. turn on the turn signal that works and listen for it. once you know where the general location is put your finger on it and if it's clicking you have found the right relay.
Mar 01, 2011 | Buick Century Cars & Trucks
My light problem is i have low beam on right side no low on left side i turn highs on and right side goes out and high on left turns on then when back to lows beams and i pull turn signal to flash high...
If you have separate bulbs for the low and high beams(4 light system), if you pull the turn signal and hold it, all 4 lights will stay on until you release the turn signal. You need to replace the bright bulb on the right side and the low bulb on the left side. If your headlights only have one bulb on each side, then you will have to replace both of them to get everything to work.
Jan 04, 2011 | 2000 Ford Mustang
Turn signal makes the dash lights flash
97 chevy blazer left turn signal makes the dash lights flash then when i turn parking lights on left signal stays on constent when engaged
Jan 16, 2010 | 1995 Chevrolet K1500
Right turn signal stays on will not flash left works.2001 jimmy
its your blinker box.. all major lights run through there
Aug 04, 2009 | 2001 GMC Jimmy
Jeep - right turnsignal won't flash
Probably a bad ground on your front right signal, or a bad bulb. Try switching the right with the left, and see if the problem stays in the same place, or goes with the bulb.
May 18, 2009 | 1993 Jeep Wrangler
Electrical problem
Find the ground wire on one of the lights and add another ground wire to a good clean metal surface and see if that fixes the problem. It defently sounds like a ground problem at one of the lights.
Jan 07, 2009 | 1983 Chevrolet Caprice
Pride Mobility Products Pride Jazzy 600 Logo
61 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
