Question about Samsung CLX 3160fn All-In-One Printer
I just replaced my black toner on my samsung clx-3160fn printer. When I print the black quality is still bad. I made sure everything is in correctly and tight. What could the problem be?
    Brigadier General:
  • 10,406 Answers
The problem is not a shortage of the toner -- it's either a dirty drum or some other problem. Either way, it's nothing that you can fix by yourself -- take the printer to a qualified technician for proper servicing. Or, just responsibly recycle the printer, and buy a new one.
Posted on Aug 22, 2010
I have a samsung clx-3160fn printer I replacEd blk toner and it keeps sayn invalid toner .... I even refilled old toner and same error... Invalid toner
I have the same problem in a CLP-300. I have tested 3 diferent aftermarket chips from different manufacturers and always the same message: "invalid black toner" and the black toner light keeps red
Sep 21, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-3160FN multi-function color laser printer. It recently started to print poorly in black (that's what I mostly print). Geniune Samsung toner carts are installed. The black is at 76%. I...
If the black toner prints like the image below with alternating bands of light and dark printing, the problem lies with your imaging unit.13911cf.jpg Specifically the developer blades in the imaging unit has toner build up on the blades. The more you use a particular color, the more it builds up to the point that it exhibits itself as faded images on the paper.
It can be fixed by replacing the imaging unit for $100+, but it will reappear again after sometime. Or you can fix the problem yourself and save yourself $100. You will need to open the imaging unit and clean the blades. I have a description on how to do this in my tips section. Or your can click on this link, http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300. Hopes this helps you.
Jul 06, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! Can...
Try printing the demo page, there's a man on there with a black tuxedo. If you see snowflakes on the black suit, you need a new hi voltage power supply circuit board. Also most of the generic toners don't work well in this machine.
Feb 05, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! ...
Go to printer properties and check whether you have selected print in grey mode and also check whether you have selected the economic mode. Rectify the same will solve your problem.
Revert back for more assistance.
Jan 31, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
Poor Printing Quality
The last time I saw that I had to replace the HV power supply and prints went back to normal...If it's out of warranty it'll cost around $150.00
Aug 31, 2009 | Samsung CLX 3160fn All-In-One Printer
My printer is not printing
My printer at work kept saying it was low on black toner. I finally replaced when I got the message Black toner supply error. I gave it a minute or two to adjust itself and when that didn't work, I turned off for about ten seconds and then restarted it. I've only had two problems with this printer and I have had to turn it off both times before it would work perfectly, if that helps anyone.
Nov 05, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
158 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
