Question about Mitsubishi VS-60707 60" Rear Projection Television
My Mitsubishi VS70707 70 turns off rite away when i turn it on and i have to plug it off and wait two days for it to work again
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
There are two things to look at; One is any sign of Glycol leaking, I can tell you what and how to look at that.
Also, do the self check this set should have (2000) model---when it turns off on its own press both menu and input buttons on front of set for longer than 5 seconds and release both.
Power light should blink two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
A added thought would be it may be a bad solder connection somewhere in the set--chassis would have to come out to see.
1,2 error code is no error detected
I need to know if you find a error code and what it is.
If all this information has told you something you do not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 22, 2010
I have a mitsubishi 62" wd62525, I replaced all
When you unplug the set it then when powered up waits for the DM unit to boot up----the green light blinks on the front for about 70 seconds and when it goes out the set can be turned on.
If this is the case I have a suggestion, let me know if I have described the situation correctly.
SD TECH
Oct 25, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My furnace stopped working. It'd start up shut down start up shut down all in the matter of seconds. Then would fire up and work. it did this maybe once every couple days then it stopped all together. ...
Replace pressure switch. If you blow any air into the pressure switch it has been damaged,check air ports for debris by looking never ,never blow on air switch they work on a very small pressure or vaccum,where your breath is to much pressure and also loaded with unwanted humidity.
boilerman56
Mar 04, 2011 | Goodman GMS90703BXA Heater
I have a green flashing light and my tv won't turn on.
This is cause of a power interuption. Try unpluging the TV from the wall, and waiting several min. Then plug it back up, wait serveral min again and the green light should stop blinking.Then turn it on.
Jan 08, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I cannot turn on the television, the word timer is flashing.
Start with plugging the unit out of the wall. Wait. Plug it back in and see if the green flashing lamp stops. If so, try to turn it on manually. If it turns on, go through setup again. If not, note the flashing pattern, it is a code for service personnel.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs45609
have a tech check your tv it might need to be repair the problem could be in the color circuit.
Apr 18, 2007 | Mitsubishi VS-45609 TV
Mitsubishi VS-60707 60" Rear Projection Television Logo
360 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
