Question about SE Electronics SE2200A Professional Microphone
SE2200a rapid signal drop off
The mic is connected to a Focusritte Saffire and into a Mac. I use Logic to record. The last time I tried to use the mic the signal was almost non existent and after plugging and unplugging the "normal" level would drop down to almost nothing within a few seconds. The mic has benn conected to the Saffire for a couple of weeks and has worked well up until now with the exact same set up. Not sure how to fix it. The XLR cable is brand new.
  • DJ Brian May 04, 2008
    Thanks Steven,
    Here is what I've done since posting this problem. I connected the same mic through my Ozone keyboard which has XLR input with phantom power and then a line out to the Saffire. Mic and cable both worked fine with a good strong signal on the Saffire LED.
    I read somewhere that the Mac firewire connection has had some issues with the phantom power on the Saffire. I can try to borrow another mic but I think the problem may be the phantom power is shot. Would what I'm describing fit that scenario? The problem is the same on both XLR inputs.
I had the same problem with my Saffire: the phantom power voltage quickly drops when switched on, causing the mic to cut out. This problem is common in older Saffires, and is well known to Focusrite support (a modification in newer-production units solves the problem).
The problem is that a tiny 100 ohm surface-mount "chip" resistor in the phantom power circuit fails due to insufficient power-handling capability. (This is "R196" in the phantom circuit.)
The fix is to replace the "chip" resistor with a "normal" 1/2 watt metal-film resistor (with wire leads), mounted upright on the circuit board.
I replaced the resistor myself, following directions (and photos) sent to me by Focusrite Tech Support.
The procedure is somewhat fiddly (a Swiss watchmaker could probably do OK). If you've never soldered before, DON'T EVEN TRY THIS, and if you've never worked with surface-mount components, I would ask your electronics-hobbyist buddy to do it for you.
Here is the procedure sent to me by Focusrite:
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SAFFIRE PHANTOM POWER MODIFICATIONS
Dismantling the Unit
Remove the 7 screws on the rear panel.
Remove the 4 screws on the underside of the unit.
Lift away the metal cover.
Remove the 4 small black screws securing the MIDI In/Out sockets.
Remove the single screw securing the S/PDIF In/Out sockets.
Remove the two screws securing this PCB to the chassis.
Gently pull the PCB away from the rear panel and move it through 90 degrees towards the front panel.
Place the unit on its front and support the PCB with some suitable non-conductive item.
Modification Procedure
All the components mentioned are located in the same area on the same PCB (see photo).
It is best to remove the coil and capacitor (as shown in the second photo), as this gives easier access to the components.
Remove R196 and measure its resistance. If it does not measure 100 ohms, replace it.
Use a conventional type (100 ohms metal film, .5 or .6 watt) mounted upright as shown in the photo. Before fitting this resistor, check that the three zener diodes DZ11, DZ12 (22v) and DZ9 (3.3v) are OK and have not shorted out. (Diodes are 500mW, 5% tolerance)
Testing units for Phantom Power problems
Connect a condenser Mic or suitable dummy load* to Channel 1.
Engage +48 switch.
Measure the DC voltage between XLR pins 2 & 1 on Channel 2 Mic Input XLR.
Faulty units usually read around +28Vdc and the voltage gradually drops.
Good unts will measure +48Vdc +/- 0.7Vdc.
* Dummy Load for testing: Solder a 20,000 ohm resistor between pin 2 and pin 1 of a male XLR plug and another 20,000 ohm resistor between pin 3 and pin 1 of the same XLR plug.
Here are the photos:
My Saffire has worked perfectly since I replaced the bad resistor.
Good Luck!
Posted on Apr 17, 2009
  • 3 Answers
Troubleshooting steps to isolate the problem:
1) The Saffire has two mic inputs - try the other one
2) Find another condensor mic to try in order to verify that the Saffire's phantom power/mic pre is not at fault.
2b) find ANY mic to verify that the pre amp on Saffire works
Got a small mixer perhaps? A friend with a mixer or pre amp?
3) Plug the SE2200a into another mic pre to see if it is the culprit.
4) Find another mic cable - no matter yours is new. I've seen this before with new cables.
5) Make sure the Saffire's built-in compressor isn't set really hard and is squishing your audio.
6) Look at the LED's on the Saffire as indication of the signal, not Logic. If it's not showing on the Saffire, Logic isn't going to see it, either.
Posted on May 04, 2008
Recording from DMX 6fire distorted
try isolating the usb that you are using by removing all unnecessary items like extra headphones, cellphones, speakers, battery backup usb connection, you name it. More than likely the static is from that. or try a different usb port if you have removed these items
hope this helps
Feb 19, 2014 | TerraTec Electronic Terratec DMX 6fire...
Just got my sE X1 bundle pack, plugged it in, set the proper settings in preferences and no signal to my Garageband?mac
To connect this mic to your iMac, you will require the following:
  • XLR mic cable
  • Recording interface or Mixer with phantom power
Jan 17, 2014 | SE Electronics SE X1 Microphone
No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Jan 28, 2012 | Music
I use a sE2200a and a BLUE icicle preamp for basic vocal recording. My problem is that the kind of work I do requires quite a bit of loud, sometimes even yelling recordings. But no matter what I do, I...
You can pad down the mic some more with a shure in line mic pad, from your local audio store, this will fix the problem, the mic is putting out too much level for the rest of your rig.
Thanks for using FixYA
Jan 17, 2011 | SE Electronics SE2200A Professional...
Frequency settings on se2200a
It is a pad..which is a switch that will 'reduce' sound level or volume which in a nutshell is useful for recording loud instruments..So switch to -10 db if placing the mic fairly close to say loud drum or horns..etc..
May 30, 2009 | SE Electronics SE2200A Professional...
SE2200a, No input signal
If my comment helped you find this problem, could you respond to the fixya questionnaire accordingly?
Apr 20, 2009 | SE Electronics SE2200A Professional...
Firewire audio problem
Hey Waterleo
I am running a very similar system. Black macbook and saffire not LE.
So this could be your problem. When you first connect the firewire cable to your mac from the saff you will see on the inputs a signal coming from nowhere. This is the mac syncing with the saff. Im pretty sure its the same with the LE but you must wait until your Line Mode(pad) lights turn green this means the two are connected. Try waiting for this it may take upto 3 or 4 mins sometimes depending if you are using the external powersupply or not.
If you have already done this and still nothing try this. FIrst plug a guitar into an input of the saff and confirm there is a signal being produced. If so your problem may be in your system prefs.
Apple menu --> System prefs----> sound
you will see a window with 3 tabs labled input, output and sound effects.
go to input and confirm that the saffire is in the below list and highlighted, the same for output.
Ignore sound effects.
Also i just looked at my saffire and i am not being rude now but i am assuming that your new to this tech. so there is a pot(knob) on the front for your saffire labled monitor, this is your main volume for the system.
hope this helps my friend.
Mar 07, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Dec 26, 2008 | Lexicon Lambda Usb Desktop Recording...
SE2200A "wind" noises during recording
Its very descriptive and is quite a common problem with less expensive condenser mics. It's due to dirt or contamination on the capsule insulator or front end circuitry of the electronics. SE should be able to fix it for not much money.
Aug 26, 2008 | SE Electronics SE2200A Professional...
SE Electronics SE2200A Professional Microphone Logo
1,001 people viewed this question
Top SE Electronics Audio Players & Recorders Experts
Michial Gueffroy
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
