Question about Sherwood RX-4105 Receiver
Sherwood rx4105 At higher volumes the receiver cuts out............... the speakers can handle the load.......usually around 42 on vol. dial goes up to 60............... is it not getting enough air flow? Scott
  • Anonymous May 27, 2008
    Same problem when the volume goes over 36 the receiver clicks off.
Can this amp drive 4 ohm spkrs
Posted on Mar 03, 2011
Sherwood RX4105 needs a air cooling system if you planning on playing loud music for 4 hours or more on loud speakers. Sherwood RX-4105 has a thermal and current sensor that will shutdown the receiver if it exceed the temperature or the current. On my Sherwood RX-4105 receiver powering my loud speaker with 12 inch woofers, I put a 120 volt AC, 9 inch, 53 watt fan on top of my receiver that is capable of blowing over 100 CFM into top ventilation holes of my receiver, I was able to crank the volume up to 50, and I had my bass control set at -8 and my treble control set +2, and my Sherwood RX4105 receiver was able to play loud music on my loud speakers for 4 hours without the receiver shutting down. I cranked the volume to 52, then receiver shutdown. I tried to crank the bass up to -6, but my receiver shutdown too. With the volume cranked up to 50, my fan kept my receiver so cool, there was very little warmth from my receiver when I put my face to the flowing air from the bottom ventilation holes of my receiver. I hooked an oscilloscope to my speakers wires of my RX4105 receiver and I hooked up my receiver to 8 ohm dummy load. I cranked the volume up to max and I viewed the wave pattern on my oscilloscope, there is distortion in the wave pattern at max volume. Distortion can blow out a tweeter in the speaker that is something you want to avoid. There highest volume I can go with my Sherwood RX4105 receiver without distortion is 55 and my receiver still put out 100 watts of power into my 8 ohm dummy load.
From my experience with transistorize power amplifiers, both RF (radio frequency) and Audio, that is capable running 100 watts or more need a air cooling system. The just a aluminum heatsink is not enough. With a 100 watt amplifier, the heatsink will not get any cooler, it will keep getting hotter and hotter until it breaks down.
Big loudspeakers draw a lot current. You need a receiver that is capable of running speakers that have an impedance of 8 ohms o less, and with a air cooling system in order to power those big loudspeakers. Sherwood RX4105 receiver is only design to run speakers with a impedance 8 ohms or more.
Posted on Jun 08, 2008
  • Craig Morrow Jun 09, 2008
    If you want to keep running the Sherwood RX-4105 and crank the volume up to 55 or over, you would have to hook up 4 speakers to terminal A, hook the 2 speakers up in series, and then hook the 2 wires from the two speaker that are hooked up in series to each channel on the speaker terminal. Make sure on each channel the red wire is hooked up to the red + terminal of the receiver and the red + terminal of the speaker, the black wire from the black - terminal of speaker is hooked up to the red wire to the from the red + terminal from the other speaker, and the black wire from the black - terminal from the other speaker is hooked up to the black - terminal on the receiver. Do not hook up all four 8 ohm speakers on terminal A and B, you will not be able to crank the volume up any higher than running 2 speakers on the Sherwood RX4105 receiver, because the 2 speakers on each channel will be hooked up in parallel. And make sure you all 4 speakers are the same kind.
    I hooked my 2 Cerwin-Vega CLS-12 speakers in series on one channel, and then I cranked the volume to the max, the 2 Cerwin-Vega speakers on one channel performed better than one speaker one channel, and plus my Sherwood RX4105 receiver hooked 2 speakers in series on one channel runs cooler than one speaker on one channel, and my receiver did not shutdown, and plus I was able to turn the control bass up from -8 to -6 without the receiver shutting down. But when I ran one speaker on one channel, my Sherwood receiver shutdown after I cranked the volume over 50 with a fan on top of the receiver.
    I hooked an oscilloscope to the speaker wires with one speaker hooked up to one channel with fan on top of the receiver, and crank the volume up the 50, my Sherwood RX4105 receiver puts out 40 volts peak to peak on the oscilloscope screen without the receiver shutting down. But when I crank the volume over 50 with the receiver putting out over 40 volt peak to peak, the receiver shuts down. When I hooked up 2 speakers in series one channel and I cranked the volume up to max, my receiver puts over 80 volts peak to peak on the oscilloscope screen, and it did not shutdown. Plus there was distortion in the wave pattern on the oscilloscope screen. You can blow a tweeter in your speaker with distortion. I backed the volume down until the distortion disappears, my receiver puts out 80 volts peak to peak with volume set at 55. A 100 watt per channel receiver puts out 80 volts peak to peak, or 28.2 volts rms on a 8 ohm load.
    Therefore, that's best way to run a Sherwood RX4105 with the volume cranked up to max without the receiver shutting down by hooking 4 speakers with 2 speakers hooked up in series on each channel.
  • Craig Morrow Jul 04, 2008
    I did some more testing on my Sherwood RX-4105 measuring the voltage and the current to the speaker with my oscilloscope to see where the RX-4105 shutdown. The RX-4105 shutdowns at 2.8 amp rms at around 64 volts peak to peak or 22.6 volts rms about 64 watts with the volume set at 50. A 100 watts to an 8 ohm speaker puts out 28 volt rms or 80 volts peak to peak at 3.53 amps rms. The Sherwood RX-4105 will not shutdown on the 8 ohm dummy load with volume set at 56 without clipping. It only shutdown on when the speakers are hooked up. I hooked up my Technical Pro HB-2000 fan cool amplifier to my speakers, and it did not shutdown when I cranked the volume up to max without the amplifier clipping.
    My conclusion, Sherwood RX-4105 has a design flaw in their amplifier protection circuit. If you bought your Sherwood RX-4105 within 10 to 30 days ago, return it and get a refund, and get another receiver. You would be better off spending more money getting another receiver that can run your speakers without shutting down when the volume is cranked up to the max, and be able to run 8 ohms or 4 ohms speakers. I will never buy another Sherwood receiver again.
    Problem Solver:
  • 7 Answers
I too have the same problem with my Sherwood RX4105 receiver shutting down whenever I turn the volume up near max to my Cerwin-Vega CLS-12 speakers. I hooked a 8 ohm dummy load to my Sherwood RX4105, and then I turned the volume up to near max, it did not shutdown. I hooked a clamp on current meter on my speaker wires, and I found out that my CLS-12 speakers was drawing more current than on the 8 ohm dummy. I hooked an audio generator to my RX4105 receiver, and went through audio frequencies on my Cerwin-Vega CLS-12 speakers with my clamp on current meter, and I found out that my 12 inch woofers was drawing more current below 240 Hertz, and it had impedance less than 8 ohms. What cause the Sherwood RX4105 receiver to shutdown whenever you turn the volume up is low impedance of the speakers on certain frequencies. Speakers is not always 8 ohms throughout the audio frequencies range. They can go lower or higher than 8 ohms impedance throughout audio frequencies. Low speaker impedance on 8 ohm speakers usually occur around the woofer frequency range. My Sherwood RX4105 will not shutdown cranking the volume up if the speaker impedance 8 ohms or higher. Sherwood RX4105 will shutdown if the speaker impedance is less than 8 ohms. The low ohmage from the speakers will get the receiver hot and then eventually will shutdown. I had to turn the bass control down on the Sherwood RX4105 receiver in order to keep it from shutting down. I also tried hooking my speakers up in series to double the impedance on one audio channel on my Sherwood RX4105, and cranked volume up to near max, and my receiver did not shutdown, and it was just as loud as one speaker on one audio channel. But when I hooked just one speaker up on one audio channel, and I cranked the volume up to near max, my Sherwood RX4105 shutdown.
I am planning getting an receiver than can handle speakers with an impedance 2 to 8 ohms. Receiver that is capable of low impedance speakers delivers high current to the speakers. But I still would need an equalizer to cut back some of the audio on certain frequencies that run on low impedance because you can blow out woofer or blow out the fuse on the woofer if I crank the volume up on a high current amplifier.
Posted on Jun 05, 2008
  • 1 more comment
  • craigwcg Jun 24, 2009
    Sherwood RX-4105 is designed to handle speaker impedance of 8 ohms or more. The reason why the Sherwood shutdown when you crank up the volume, because the speaker is has some low impedance on certain frequencies less than 6 ohms in which that would overload the receiver, and then receiver would shut down. There are one of the two things that you could either do, you would either need to find speakers that are already on the market that have an impedance compensation network that would maintain near 8 ohms impedance throughout the audio frequencies in which that would be expensive due to the time consumption into designing it, or you could either find a high current receiver or amplifier that is capable of handling speaker impedance of 8ohms or less. I had to order some speaker crossover parts to build my own external in-line impedance compensation network for my speakers in order to make them campatible to my Sherwood receiver. And now, I can crank up the volume up to 55, and my receiver had never shutdown every since I have that external speaker impedance compensation network in-line. My Sherwood receiver runs cooler than it did before with that external impedance compensation network in-line also. But I still had to put a 10 inch 55 watt fan on top of my Sherwood receiver in order to keep it cool while I playing loud music for 4 continuous hours with the volume set at 55. In a 117 square foot room running my Sherwood RX-4105 with the volume cranked up to 55 into my 2 speakers that have 12 inch woofer, 6.5 inch mid-range, and 1 inch dome tweeter with the external in-line speaker impedance compensation network is just like being in an 8000 square foot nightclub with 20000 watt sound system. My ears gets sore with earplugs on after playing 4 continuous hours of loud music. Not all speakers have the same characteristics. The speaker impedance compensation network has to be designed and built accordingly to speaker's characteristics. If you have electronic engineering background, you could build that external in-line speaker impedance compensation network for your speakers yourself, and that would cost around $120 in parts in order to build it for 2 speakers depending speaker's characteristics.
  • craigwcg Aug 20, 2009
    I just bought a sound pressure level meter to check my Sherwood RX-4105 hooked up to my 2 speakers with 12 inch woofers with my external speaker impedance compensation network inline with the volume control on my Sherwood cranked up to 56, my speakers are pounding my 117 square foot room with 124 decibels at of sound pressure level at C weighting in which that is equivalent in being in a concert, or in a 8000 square foot nightclub with a 20,000 watt sound system, and my Sherwood RX-4105 in drawing 2.5 amps of current from the 120 volt AC wall outlet. Without my external speaker impedance compensation network inline, with my Sherwood hooked up directly to my speakers with the shutdown system in my Sherwood receiver temporarily disabled with the volume cranked up to 56, my Sherwood receiver draws 3.5 amps from the 120 volt AC wall outlet, and my speakers are putting out 120 decibels, and then I re-enable the shutdown system in my Sherwood receiver, and my Sherwood receiver hooked up directly to my speakers, and then cranked up the volume to 56 on my receiver, my Sherwood receiver shutdowns immediately. Speakers need an impedance compensation network in order to work with that Sherwood receiver, otherwise that Sherwood receiver would shutdown or breakdown.
  • craigwcg Dec 05, 2009
    In order to get my Sherwood RX-4105 to work on my speakers with the volume cranked up to 56 with the bass and treble control set at 0db or tone direct, I had to fix the low impedance problem on my speaker by building me an external parallel LCR impedance compensation network hooked up in series on the positive wire of the speaker line between the audio amplifier and the speaker. The external parallel LCR network is precisely tune on the audio frequency that have the lowest impedance curve, and it raises the speaker's low impedance curve to 7 to 8 ohms, and it provides equalization. In order to set this parallel LCR network up, you need some test equipment, and some electronic background. It would be very difficult set up without electronic knowledge. Some speaker designers use that parallel LCR network in their speaker designs, and you can find it in some speaker designing books. Most speaker manufacture will not use that network because they don't have extra time and money to build it and put it in their speakers.
    So if your Sherwood RX-4105 receiver shuts down after you have cranked up the volume to 56 with the bass and treble control to 0db, have a technician to check your speaker's impedance to see if it is above 6 ohms throughout the audio frequency. Right now, I can crank up the volume on my Sherwood receiver to 56 pounding my room with 128db for 6 hours after I ran 12 gauge speaker wires, and my receiver has never shutdown, nor blow out any fuses on my speakers every since I have that external LCR impedance compensation network inline.
    Novelist:
    Champion:
  • 236 Answers
You may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
Posted on May 04, 2008
Shut up stereo protect mode?
Protect mode is on because something in your speaker wiring is wrong, or you have a broken speaker, or it\'s too late and you already fried one or more of the amp\'s output transistors.
You gotta fix the problem. Not remove the safety guard and carry on with a busted machine.
Look for wires touching between the speaker terminals or on the backs of the speakers. If you done a half-ass job of wiring up then this is the most likely cause.
If you can\'t find bad/frayed wiring, then disconnect all the speakers out the back of the amp. Switch the amp on. Does it trip out? If no, that\'s good. Turn up the volume. Is it still okay? If yes, that\'s good. You haven\'t yet killed the output transistors. If it goes in to protect though, ut oh. It\'s Repair Shop Time.
If the amp is okay, then power off and add one speaker. Power on with the volume down. If it trips either at no volume or when you increase the sound, then you got a bad speaker and you just found it. Repeat the process, adding one speaker at a time. Make sure you put Vol to minimum and power off each time before adding the next speaker.
Sep 14, 2014 | Sherwood Rd-7405hdr 7.1-channel 70-watt...
Everytime i try to play my system at full volume it cuts out then keeps playing and carries on doing this to i turn it to a certain volume
First of all find out the recommended speaker impedance for the receiver. Then find out the impedance of the speakers you are using along with it.
Simple rule is the speaker impedance can be higher but not lower than the recommended value. If it is so the receiver will run hot and if you turn up the volume higher it will run even hotter and then the protection circuit will cut off the Amplifier output to prevent burn out of components. Even if you have one defective speaker this cut off can happen. To confirm defective speaker -- disconnect one speaker at a time and turn on the amplifier and play it at cut off volumes.If by disconnecting one particular speaker the Amplifier does not cut off -- THAT SPEAKER HAS A SHORTED COIL and needs replacement.
Apr 03, 2011 | Philips Audio Players & Recorders
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
Hi Strange problem with Marantz pm7001 When ever I turn the volume upto around 1/3 and 1/2 of the way, the amp cuts out and reset it self down to minimum volume. It seems like the amp ins't enough power...
What's probably happening is that the amplifier is shutting down or cutting back the volume as protection from damage. You may have a partial short in the speaker wiring that is not a problem at lower levels, but at higher ones causes the amp to see too low a load. There may a problem with a speaker or crossover component that is breaking down at higher volumes. Or something in the amp's output stage is unable to handle the load.
Test the system with a known good speaker system and length of wire and see if the trouble continues. If it does, you'll know it's the amplifier that needs to be checked. If the test speakers can reach normal volume, you can start checking the wiring and other speakers for the source of the trouble.
Mar 13, 2011 | Marantz Audio Players & Recorders
Keeps turning itself off
If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
May 23, 2010 | Sherwood RX-4109
Concerning my Sherwood RD-7500 6.1 Channels Receiver
That still doesn't make much sense. Please slow down and say what you mean with detail and accuracy. We're not mind readers. You are our eyes and ears.
Is the following true?
"Video 1" video output goes to the TV and works ok. Though it is irrelevant since you don't have a video problem. That you mention it at all is distracting. Do you feel it is important?
Tower speakers are the main or only speakers. Do they work ok for other sources?
So, to be clearer, you have a problem with a particular sound source (the game console) being less loud than usual. Is it unusable or drastically different in level than other sound sources?
Where and how is the game console connected for audio? Can you move it to another input?
Have you considered that the game console or its settings may be the reason volume is lower than usual?
Jan 19, 2010 | Sherwood RD-7500 Receiver
Radio cuts off and back on seems to be vol related
This is cause by many things one of which is a faulty speaker that is going short when operated at high volume. Another is the wiring supply the power to the radio is not "thick" enough hence not able to supply the demand for extra current. Had this same problem with Golf II which I replaced the main supply wire and after that it went to full volume with no cutting off.
May 12, 2009 | Sony Car Audio & Video
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
Inside speakers(1) and deck speakers playing (2) output is at very different levels
The things that affect the outside vs. inside volume are distance and ohms of the speakers if the inside ones are 4ohm and the outside are 8ohm then there will be a drastic difference in volume, also if the inside speaker wires are shorter by 20 feet then there will also be a drastic differences in volume.
What you can do is have a separate amp for inside and out with the input coming from the same receiver. The other thing you can do is put an inline amp for the outside speakers with this you can also balance the volume.
When you have longer wires you drop more voltage across them then when you have shorter ones you also has losses due to electrical interference from lights and the household wiring. To combat this I would suggest an inline amp so that you can balance the speakers more effectively and drop out most of the noise (mostly hum that you hear at a higher volume) that you are probably getting unless you put on filters on the speakers. But if you want to keep it simple than you need a separate amp with a common input, this way as well you can control the speakers to have a different volume for different situations.
Jul 17, 2008 | JVC RX-8010V Receiver
Sherwood RX-4105 Receiver Logo
1,137 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
