Question about Maytag Kitchen Ranges
Maytag oven - error message sa6. oven wont work. stove top works
  • 3 more comments
  • Anonymous Dec 14, 2008
    error code SA6!
  • Keith Steinhoff Jan 15, 2009
    Error message SA6 displayed. Can't clear error, oven inoperable, stove top still works.
  • bretts710 Feb 05, 2009
    I have the same
  • Rich Erickson Oct 06, 2013
    Hold the clock button for 10 seconds and it will reset
    Press the clock button and hold for 10 seconds until the time blinks. Then it is reset.
If you are receiving the SAb code your range is in the sabbath mode. I don't know what this means but it is really easy to fix. Press and hold the clock button for 5 seconds. The code will flash, let go and it is reset.
Posted on Mar 13, 2009
Thank you so much, u had the same problem and your directions helped me out. Thank you so much!
Posted on Feb 13, 2010
Worked perfect. Thank you.
Posted on Mar 21, 2009
Stove works oven wont turn on. now is reading fault code (SA6). what does that mean? and how do I fix the proble
If sab Push and hold clock button in for a few seconds.When it clears, the oven should work fine. God-Bless! Just let me know if that works. It is in sabbath mode. Research said it is sab not sa6,
Dec 28, 2015 | Maytag Range Oven Part - Oven Temperature...
Have error message on my ne fiigidaire gallery gas range...error Sd...oven will not work and timer etc will not function properly
Some stoves have an override on the oven side... oven pilot light must be lit or it will go to safe mode. if it is an auto light then check the fuse usually located up by the top left side on bk of stove.
Jan 02, 2015 | Frigidaire Gallery 30" Self-Cleaning...
I AM GETTING A ERROR CODE ON MY STOVE SAB OR SA6 HOWEVER NONE OF THE BUTTONS WORK
This is the Sabbath feature on my Kenmore Elite Electric Slide in Range. My oven manual says to press both the (timed oven) "cook time" button and the "delay start" button at the same time for approx. 3 seconds and this should shut down the feature. I had the same problem, tried the above and it worked.
Mar 06, 2011 | Kenmore 46564 / 46565 / 465 / 6646569...
Maytag oven wont bake. stove and broiler work and ignitor for oven looks like it turns on but wont light gas up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 21, 2010 | Maytag Kitchen Ranges
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Can't start oven. Stove top works fine. Maytag
top burner burnt out we replaced it with a new one and it still doesnt work please help? Ron
Jul 09, 2009 | Kitchen Ranges
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Kitchen Ranges Logo
1,432 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
