Question about EuroCave Comfort 260 - Black Solid Door
Code od flashing on digital read out - EuroCave Comfort 260 - Black Solid Door
Tip
OD light flashes
The flashing OD light indicates there is a problem in the transmission control system. When the Transmission Control Unit detects a malfunction it will flash the OD light and store a Diagnostic Trouble Code (DTC) in the computer. You will need to have a Ford Dealer pull the codes and determine exactly what is wrong.I wish I could be more specific, but there are about 120 different reasons for the flashing OD light.
on Feb 24, 2010 | Ford Expedition Cars & Trucks
TCM or shift solenoid
SCAN IT.
WHAT CODE?
on 96 cars some can only flash codes.
so read the manual FSM>
or login to alldata.com and read how to scan your TCM.
on about 1997 most cars the PCM gets all TCM codes side loaded.
prior to that , its a jumper wire, to the TCM and OD blinks some tranny lamp blinks.
RTM
Feb 09, 2014 | 1996 Toyota Camry
CD4E OD does not downshift out of gear when decelerating, OD light is now flashing, and I can no longer move in forward gears.
Hello
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Sep 04, 2012 | Cars & Trucks
On my 1999 Ford Windstar the overdrive light flashes
on ford's the Od light flashes to indicate there is a fault in transmission
get codes downloaded there in there
reminder most big chain auto parts stores will offer to read codes for you in there parking lot for FREE they wanta sell you the part if you need one
Jun 29, 2012 | 1999 Ford Windstar
What does it mean when your O/D off light is flashing and the transmissionis slipping
Feb 24, 2010 | 1996 Ford Explorer
OD off Light Flashing on my 1998 Ford Explorer XLT 4.0 V
The OD light is flashing to alert u to the fact that some kind of fault has occured in the transmission, the problem is in many cases a slipping condition, you need to have the trans control system tested for the trouble codes that are stored when this light flashes, this will let u know what the problem is and a direction to follow to repair it.
May 26, 2009 | 1998 Ford Explorer
EuroCave Comfort 260 - Black Solid Door Logo
188 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
