Question about Tricity Bendix WDR1040W Front Load Washer / Dryer
Need a timer and where do i get it from for a bendix front loader l105rx
    Champion:
  • 245 Answers
Look up SERVALL for your closest location. Or from an appliance parts distributor. All you need is the model# and what it is.
Posted on Aug 22, 2010
Will a Tricity Bendix AW1000W Washing Machine run on a clock timer?
hi your machine will remember prog if there a power cut and restart from where it was interupted. So if you load the machine and start it then turn the power off on the timer it will continue when the timer switches back on (yes is the answer)
Nov 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Clothes smell mildewy after washing and drying
This is a common problem with front load washers. Mildew tends to grow in these washers due to it use of less water than top loaders, often leaves dirt and soap residue on the machine. To help prevent mildew, wipe the door gasket, leave door and detergent dispenser open after wash. Wash once a month empty, with hot water and vinegar to kill the mildew in the machine.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need a counter weight 4 a tricity 800 front loader washer
I am not sure if its the front or rear you want but here are the genuine Electrolux part numbers and prices.
Front weight. 1260582109. € 36.99 + vat.
Rear weight. 1260399207. € 21.50 + vat.
If you get in touch with Electrolux they should be able to help.
Hope this was helpful.
Good Luck.
May 10, 2010 | Tricity Bendix AW850W Front Load Washer
What is the quickest wash cycle for the tricity bendix wdr1040w front loader
This is relating to the 2006 model.The times are not printed in most manuals like they used to but on this machine most probably the quickest prog. would be( 4 ) this is 3 rinses and a long spin at 40 deg. If you are experiencing long times on your washes do check that your water pressure is good as that will shorten the duration of all cycles and save on electric.
Good Luck
May 04, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Door won't open bendix BIW1000 W
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Tricity Bendix AW1000W Front Load Washer
Bendix aw1054 front loader wont fill as continually pumps water
If the pump is on all the time, then you definately have a timer and or control board prob, the only other possibility is if the drain outlet hose is to low.
This will cause the water to syhon out , thereby giving the impression that it is pumping out all the time.
To check this, try lifting the drain hose higher, and see if that solves the prob.
Plz rate my solution.
thanks.
Jan 12, 2009 | Tricity Bendix AW1054 Front Load Washer
Bendix w1063B Allegro Front Loading Washing Machine
Make sure that the spin cycle is complete.
it has a timer/switch set @ about 3 min. You will observe a yellow pilot light.
It will show with a green pilot light when to press the open button.
Good luck,
marty
Apr 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Bendix L 105 RX
you can get it here
http://www.serviceforce.co.uk/pdf_search1.asp
you will need to enter the model nu like this L105 RX
it took a while to find
Feb 18, 2008 | Tricity Bendix AW1000W Front Load Washer
How does this machine work??
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
chassg,
It is normal for the door to release after 2 or 3 minutes, its a precaution set by the machine; do not force the door. And surely the cycle must end for you to have a nicely washed clothes. Don't try to stop front loaders inbetween, less probs for you.
Nov 19, 2007 | Tricity Bendix AW1054 Front Load Washer
Tricity Bendix WDR1040W Front Load Washer / Dryer Logo
42 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
