Question about Nintendo Wii Console
Is there a place to connect a ethernet cable to the wii, if so where is it at
    Problem Solver:
  • 4 Answers
You must purchase a USB Ethernet adapter for it. Factory it only comes wireless, but there is an adapter.
Posted on Aug 22, 2010
I m trying to connect Internet but I m getting the error code 51422 Please help what should I do?
1. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
2. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
3. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
4. If possible, try another Wii LAN Adapter.
Aug 23, 2011 | Nintendo Wii Console
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 22, 2011 | Nintendo Wii Console
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
May 05, 2011 | Nintendo Wii Console
I'm trying to connect to the internet from my wii with my tv to watch netflix... how do we connect to the internet
Connect your wii using a Ethernet cable from the Ethernet port on the back of your wii to the router, or connect the wii using wifi.
The wii t your tv as usual and that's it.
Mar 17, 2011 | Computers & Internet
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
    Connecting directly to a modem:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
Sep 13, 2010 | Nintendo Wii Console
Help connect WII to in internet would like to talk to my friend
Try this--------------->http://nintendo.okayblog.net/how-to-connect-your-wii-to-the-internet.html
If not there is an ethernet port in the back of the WII plug in the ethernet cable. You may need to buy another cable or a splitter.
Feb 20, 2010 | Video Game Consoles & Games
Hi i have an ethernet cable to my hub from my wii
you probally selected wireless connection instead of wired connection
hope this works,
Luke Wilcox
Dec 29, 2009 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
How do i get connection 24 on my wii?
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
Mar 09, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
22 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
