I have no problem with my whirlpool cabrio washer, just a question. When you start the washer it always goes to warm/warm for the water. I whould like it to go to tap cold/cold,how can I program that in or can I? Email address is Danny
  • hueyyy1 May 04, 2008
    Thank you for the info.
  • 487 Answers
When you start the machine you can select cold-cold but there is no way to program it to automatically do so.
the only way is to always select colors/darks as the preset for that one is cold/cold.
Good luck
Posted on May 04, 2008
How do I fix my whirlpool cabrio washer is showing code sD
Ideally, you just run the washer without any detergent and it'll rinse out all the soap. Try that first. My Cabrio started doing that all the time, then stopped spinning out all the water. It had a host of problems and I opted to replace the washer. Hopefully the water rinse will fix the problem for you.
May 23, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
New whirlpool wtw6500ww cabrio washer has overflowed with water every load I ran today. What am I doing wrong? It ran over with every size load.
There is a clear hose that goes from the tub to the pressure sensor on the control board. It tells the washer when to shut off the water. It is probably either punctured or disconnected, or the pressure switch needs to be replaced. If it's new its probably still under warranty and you should have whirlpool fix it.
Jan 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
