Question about Microtek 715C 17 in. Flat Panel LCD Monitor
Microtek 715c power supply requirements. I found this monitor by the curb and gave it a 17.5 vdc switched power supply. It works quite well except the power light goes blank while asleep and acts like there is no power to it. If I disconnect power for a bit and plug it back in it'll come back. Once it's on it stays on fine. If I knew the proper power requirements it might work like normal. Does anyone know? Thanks for any replies.
  • 903 Answers
SuperWarehouse.com just says it requires anywhere from 110-240 volts AC (which isn't very specific) and uses 48 watts. I don't see anywhere online that lists the DC power output... sorry. If you could get a manual for it that might help.
Posted on Aug 22, 2010
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
I need an internal pin out diagram for a 4 Pin connector to connect power supply to a hp pavillion f70 monitor. I do have a power supply with same specs but it has a normal plug with outer as +ve and Inner...
12 VDC , 4.16 A (4,16 A) Frequency: 50/60 Hz Power Consumption: less than 36 W in operating mode.
I think the other two pins are not used. It just requires the 12 Volts DC. +ve and -ve, positive and negative, respectively.
Feb 10, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
I have a Microtek 17 in monitor and recently it has started to flicker badly when switch on after a couple of minutes it settles down to normal. Can you offer any comments re fixing this problem? Many...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 05, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Microtek 715C 17 in. Flat Panel LCD Monitor Logo
67 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
solver2010
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
