Program does not move on as there is data error on the spin cycle due to wrong commands from the water level sensor/ program drive.
You must see if by choosing another program the fault changes, if so the drain valve or pump is faulty.
Check for dirt in the inlet, outlet valves, clean and set.Check the water level sensor.
This must clear the issue.
