Question about Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster
I was given this toaster as a gift from my daughter. It failed after being used 4 times. Being a retired electronics engineer, I took the unit apart and found that a small relay that operated the toaster heating element had failed. The manufacturer told me that they do not do repairs or provide replacement parts. If I can't replace this part, my new toaster is junk
  • Joseph Patterson
    Joseph Patterson Jun 04, 2012
    I went to the Mouser web site, and although they had many parts, there was none with the part number 893-812H1CS24DC. Is there another number that may be cross-referenced?
Mine had the problem with the toaster not getting hot in either the toaster or the toaster/egg positions, I read several of the solutions which indicated the relays could be the problem, called Mouser Electronics and one of the techs cross referenced the original relay (they are both the same) and sent me a couple, only 1.58 each, part # 893-812H1CS24VDC. On mine the toaster relay feeds the brown wires only, the egg relay has the blue wires. Facing the small circuit board, the two square black relays are approximately 1" square, the toaster relay is on your right. The soldering and desoldering is simple if you have some experience, wait until you get the new one so you know what pins to desolder. So far mine is working great and I have an extra for when the egg relay goes out. Thanks for leading me in the right direction, David
Posted on May 01, 2012
  • David Devenburg May 01, 2012
  • 17,130 Answers
Unfortunately this is the sadddest part of our enviourment problem but the best part for the economic boom. Unless the unit is discarded the companies cannot surrvive.Hence most of the models are scrapped for no reason to make way so that the product sale continues.
If by cleaning the relay the fault can be rectified , try to do it with a good contact point/switch cleaner.
If the relay coils are damaged, the use an external relay if a similar type is not available.
the last option is to source one from a damaged set, sets discarded for coil failure etc..Try to salvage this part from old service shops,junk yards or second hand dealers.
Hope you find my tip helpful.
Posted on Aug 22, 2010
  • 1 more comment
  • Joseph Patterson
    Joseph Patterson Aug 22, 2010
    I should have stated that the relay is solid state. Thus solutions that work with electromechanical relays won't work here. Either the part is replaced, or the toaster itself is "toast". One possible "solution" is to short across the relay, and pull the plug when the toast appears to be done. Thank you for your suggestions. They have helped to point the way to other "work arounds".
  • Donald DCruz
    Donald DCruz Aug 22, 2010
    In this case you can use a high value Thyristor - Mosfet- for switching but might have to improvise with the load of the heating coils.
    Thanks for the comment.
  • rjhkmh435 Jan 09, 2011
    Hi guys... I got this toaster for myself 2 years ago.
    Absolutely LOVED the egg making feature for a full year. Than it stopped....
    Tried to disassemble but found nothing obvious... so at least I still got a toaster.
    If anyone gets a cure, I love to see it.
    Hey...it still makes toast.......
    Ron H
Osher toaster oven
check breaker and plug --if power to unit will need a meter to test the controls,switches and elements
Sep 05, 2016 | Oster 003905-000-000 4-Slice Toaster...
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
I have a sharp carousel 1200 watt and my daughter cooked a toaster strudle for 2 mins and the microwave shot flames and has no power any more. it is approx 7 yrs old, would this do that or possible another...
It sounds like the magnetron has failed, and the main fuse has blown, this is not related to what your daughter put in. This gave out because of parts failure, due to repair cost consideration should be given to a new one because prices have come down.
Feb 23, 2011 | Sharp Microwave Ovens
We have a 4 piece Bella toaster given as a Christmas gift. Unit is already defective. From the moment it was out of the box one had difficulty pushing the handle down. Now it one us unable to push the...
Yes! the items built today don't have the quality of yesterday, the only solution is have the person who originally bought the toaster take it back for a exchange providing there is still warranty on the product. But even If the warranty is gone I think a visit to see the store manager would be order they don't like the bad publicity especially if the store is full of prospective buyers.
Jan 21, 2011 | Microwave Ovens
Manual/instructions
the manual can be found here...
http://www.hamiltonbeach.com/use-and-care/use-and-care.php
Enter "Toaster Ovens"
and, then "31197"
you will be able to download the manual here...
Jun 30, 2010 | Hamilton Beach 31197 120 Watts Toaster...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Krups toaster won't work.
I do not know the exact inner workings of this toaster, but I can suggest what the fault may be.
Many of the toasters use a separate high power section in the eating element for toasting. This part of the element could have gone defective. There is the possibility the computer board that directs the power for the higher temperature mode for toasting has failed.
The only reliable way to know is to try the computer board, element assembly, or the switches if the switches are on a separate module than the computer board.
Just to add... These toaster units usually have a thermo protection fuse. These fuses have a temperature rating. It would be in series with the element. This fuse may have failed. This is a common fault in many of these types of units. This type of fuse is rated in Degrees C or F, and not in Amps. it is a thermo fuse.
Apr 02, 2017 | Krups 287 SensoToast Deluxe 4-Slice...
Back to Basics egg toaster
My egg cooker stopped working, so I took the unit apart. To answer your question, I did not see a fuse inside. One way to tell if it is a power problem to the mother board is to observe whether the LEDs light up or not after pressing the switches. If the LEDs don't light, there could be something wrong with either a power component or a power connection.
In my case, the toaster worked fine. Usually these problems are caused by loose connections. Sometimes it is not obvious where the loose connection is. All I did was loosen and re-connect the wires to the egg cooker and also to the board they came from. I also shined up the toast slide button copper connections with a nail file. This was just a precaution, since the toast slide button had to be working (i.e. it still toasted, just didn't cook an egg).
So far, it seems to be working, but time will tell. If the problem was due to something other than a loose connection, it will happen again.
Apr 14, 2008 | Kitchen Appliances - Others
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster Logo
569 people viewed this question
Top Back to Basics Kitchen Appliances - Others Experts
Ian Summerfield
Ian Summerfield
L Vincent Testa
L Vincent Testa
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
