In rinse cycle the water does not seem to fill the tub. I travels right through to the drain. Then of course it will not spin. I have only had this washer 3-4 weeks! PS; THIS IS INTERMITENT
  • 122 Answers
Drain hose may be to far down drain, should only be 6 inches down drain, causing water to syphon
Posted on Aug 22, 2010
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Washer not draining
sounds like you need to replace the pump
Aug 30, 2017 | Whirlpool Washing Machines
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
When the clothes are wet at the end of a cycle, check these:
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
