Question about Singer 3116 Simple
The needle on my brand new singer simple sewing machine is not centered for straight stiching and only moves to the center when you set it on zig-zag mode. Is this how it's supposed ot be or is it defective? One would think that the needle should be centered with the center of the presser foot? Appreciate the help!
  • Anonymous Mar 28, 2014
    a needle dropped in side and destroyed only one gear the other was not damaged It sewssome programed setting but will not do #20, It will only stich straight on that setting? Its like it will not pick up that out side stich. Tony K Omaha
    Scholar:
  • 109 Answers
I don't know the machine but most likely this machine is made for quilting like most of them these days. (One of mine is like this too.) It is set to the left of center. It's not defective. You might look in your manual to clarify it or call the dealer. If they think you want a new one, they will check the answer for you!
Posted on Aug 23, 2010
My singer 6160 needle is not centered anymore. It is slightly to the left. Can I readjust to be centered once again?
yes, those needle bars can be adjusted. try switching from buttonhole maker to straight stitch. When making buttons it will move to one side or the other, if no button hole maker, switch to zig zag and back to get the needle to reposition.
Jul 29, 2017 | Singer Sewing Machines
Brother sewing machine model AS1430S not picking zig zag stich....on zig zag stich option it is only giving straight stich.....plz help
Try a brand new needle. If that doesn't work, then the machine may be slightly out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Brother Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
When i use the zig zag stich, sometimes the stich falls and does not zig zag
try a new needle--one for the fabric being sewed
could be a problem with the cam that does the zig zag, you might need to have the machine checked
if your sewing with light weight fabric also try using stablizer
Mar 18, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
How do you fix a left of center needle on a Morse Apollo 6500 sewing machine?
Is this machine new to you? Some of the older (but goodie) machines have a needle that defaults to the left. (I have an old Nelco that has this--great machine, just takes getting used to sewing with the needle in that position.)
Otherwise, I suspect the machine needs a thorough cleaning and oiling because the old oil may have dried out and is causing it to seize.
Jun 08, 2017 | Sewing Machines
Needle position
Hmmm sounds like an issue I had/have with a singer stylist. There is a knuckle part that connects the zig zag mechanism to the needle bar. Mine had a pin that kept slipping out. When I took it apart (and lost the pin) I also discovered that the "round" holes the pin went into were work out and were more like ovals. The machine is now a parts machine.
Dec 09, 2012 | Sewing Machines
Needle does not align with the hole and presser foot
Sounds like a bend needle, try a new one, or else your needle plate and foot is for straight stich, put the machine in center needle postion, and reduce the zig zag to 0 or none.
Good luck and happy sewing, please rate my solution
Mar 12, 2011 | Singer Sewing Machines
Needle arm is not centered and will not center. when machine is turned on the needle arm moves completely to the left outside of the range it should be in.
You probably have your machine on a different stitch than a straight stich, such as zig zag or a button hole.
Jun 07, 2010 | PfaFF Creative 7570
ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Aug 28, 2009 | Singer 2638 Mechanical Sewing Machine
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Singer 3116 Simple Logo
79 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
