I have a samsung HCL473W and curved blue lines have appeared on the sreen
  • 8,617 Answers
Try turning down the blue G2 slightly if that doesnt help you will have to trouble shoot the blue crt drive circuit or possibly replace the blue CRT itself.
Posted on May 04, 2008
Blue lines on screen
Go to a unused video input and examine the screen----if you see blue with slightly curved trace lines the blue screen control for the set is set just a bit too high.
Dec 03, 2012 | Samsung PCL5415R TV
Samsung HCL473w lamp
Call FOX 1-800-227-5369 they have Lamps
BP96-
Jan 02, 2010 | Samsung HCL473W 47" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Samsung HCL473W 1080i red shadow & words are curved at top/bottom
I believe you have convergence problem on your rear projector TV. It require to replace may be 2 IC output convergence or the convergence drive, after replace those component you need to readjust convergence which mean you move the RED GREEN BLUE to be 1 on top each other you must have the remote control and service manual to get into the service mode, if you thing you can get those part in your country the service manual I may help you with that, ask your husband if he like to challenge it. I hope that is give you some ideas
Cheers
Dec 17, 2008 | Samsung - Projection TV replacement lamp...
Samsung Projection tv Blue line across the screen curving up
This set does not have a bulb. It is a tube type projection set that sounds like it has a convergence problem. Call a qualified tv repair company.
Jun 24, 2008 | Samsung - Projection TV replacement lamp...
I need to really find an HCL473W tube, can you help me??
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
This requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Apr 19, 2008 | Samsung HCL473W 47" Rear Projection...
Samsung HCL473w picture distortion
easyab
Feb 18, 2008 | Samsung HCL473W 47" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Descending curved line on screen
if the tv has a portal on the side open it up and make sure the screen is not out of it's track, don't set anything on top of the set it could make it happen also
Apr 13, 2007 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
