Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My sony bravia 500 is on standby, I disconected for a few minute, but nothing change, what do I have to do
  • 1,476 Answers
Jeanpmansur,
If your unit worked fine before and now will not turn on then it should be flashing the standby light with a code which will help to diagnose the problem. Sony has equiped all it's models with this feature to help us out. Some feedback on that issue would be helpful.
Considering your unit worked OK and now is in standby and will not turn on we can assume the power supply is ok or it would be totally dead. The problem is more than likely in the main or control board.
If there are no sequence of blinking lights you should unplug it and remove the back. Not difficult but alot of screws. Make sure you note exactly where each one goes as many times there are different sized and length screws in these units.
Without knowing your troubleshooting skills it will be hard to walk you through the process but these days most TVs have solder issues, it's just a matter of determining which board. They aren't that expensive or hard to replace.
http://www.encompass.com has the service manual as a pdf download for free. After looking at it I would say that your Bu board is bad. The service manual has a chart which works in conjuction with you programming the set for auto diagnosis. If you download the pdf and follow the instructions I believe you could probably determine which board you need and get it from encompass and install it.
Thanks for using FixYa and for the great rating!!!
hardrocko
Posted on Aug 22, 2010
What would be the cause? Sony Bravia standby light 3 blinks times any ideas?
try re-closing your lamp door. indicates possible lamp door/switch problem
Jul 19, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
Sony KDL-46z4100 standby light blinking 12 time with few seconds gap continiously
12 blinks of standby light indicates 'Scanrate error'. You must have thorough knowledge in electronics to proceed. Actually, this is not a user repairable fault. it is very skilled work.
Jul 09, 2012 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia KDL 32S2030 is showing a flashing led standby (4 flashes/2 secs/4 flashes. I can unplug the mains cable, leave it for a few minutes and when I pug it back in it will re-set to the green...
I'm not a service tech, but, I do have a copy of the service manual. It says the TV has a self diagnostics and according to the chart, 4 flashes indicates a backlight failure.
Oct 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
No picture.. standby light on sony bravia lcd
try to replace the regulator or the horizontal out of the t.v. and when nothing happen maybe the jungle i.c.
Sep 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My sony bravia hdtv will go to standby mode after a few minutes of operation
the tv can go into standby for many reasons, overheating, power problem, switch ie: on/off or board problem. your best bet is to tack it to a repair shop. if it is new take it back. sorry but there is not much you could do your self.andy
Jan 02, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Aug 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
