Question about ASUS S6 Notebook
Trying to remove the hard drive from an asus S6F. removed all the screws from the back but when I try to remove the top it wont budge. I really need to know how to take it apart as the hard drive has died.
Geekman
  • 32281 Answers
SOURCE: trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Posted on Mar 26, 2009
  • 9 Answers
SOURCE: How do i open an Asus eeePC 1008HA netbook to
i think this link can help u
http://www.liliputing.com/tag/ram-upgrade
Posted on Mar 15, 2010
  • 19 Answers
SOURCE: my Asus S6F laptop battery wont charge it sits on ...
1)Reason:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
2)Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
come from laptop battery site:http://www.buy-battery.ca/faq.htm
Posted on May 27, 2010
  • 10406 Answers
SOURCE: Does anyone know where I can get a repair manual
Did you remove the keyboard (being sure to NOT damage the ribbon-cable between the keyboard and the motherboard), to look for more screws?
Did you remove the battery, to possibly expose more screws?
Posted on Aug 22, 2010
Geekman
  • 32281 Answers
SOURCE: Hi, I am wanting to take the keyboard off of my
There may be a screw on the bottom of the laptop under the middle of the keyboard.
Posted on Apr 14, 2011
Asus et2010agt service manual
below is a link to the asus site and the user manual, I did lok at the pictures and there are four screws on the back of the unit, I would say the back cover is removable for ram or hard drive upgrades, if in doubt email Asus and they will help you out.
Sep 22, 2012 | ASUS Eee Top ET2010AGT - Athlon II X2 50u...
Removing the hard drive from my ASUS B43J-B1B
Lol, yeah the black plastic tab is very common in laptops. It's there to give you leverage to slide the HDD out of the connector. You can also just put the palm of you hand on the drive with a little pressure and give it a good **** and it should come out of the connector. Manufacturers are very good about putting "warrenty void if sticker removed" stickers on parts they don't want you to touch FYI.
Jul 10, 2012 | ASUS B43j-b1b 14 Business - Laptop Black
How do I install a new hard drive for s6f????
my utility recovery loos, where I can do it?
Feb 01, 2011 | ASUS S6F Notebook
At start, led is blinking, but after few\seconds everything stops. No start
Remove your battery and connect tomains power and try again to start! If it starts it's most likely your battery has completely gone dead and requires replacement!
Oct 09, 2010 | ASUS S6F Notebook
My Asus S6F laptop battery wont charge it sits on the charger and when you unplug it the battery its dead even after leaving it on the charger for a couple of days. I have bought new batteries for it but...
1)Reason:
2)Solutions:
May 20, 2010 | ASUS S6F Notebook
A new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
Mar 29, 2010 | ASUS Eee PC 1000HE Netbook
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The heating element( I'm guessing) inside the dryer, behind the panel with the 3 screws got really red hot and smelled of smoke. I have a gauge thing from the hardware store to check to see if the heating...
last thing u wanted to do was remove the three middle srew they hold the drum .
u are going to need someone else to help,first try to reinstall the srews .
after reinstalling
top left back there is a thermal fuse this fuse goes when the element goes element about $95.00
fuse 13.00
under neath the panel next to timer 1 black screw on other side 1 more screw remove
remove casing with both timers.more screws
un clip all wire harness
all screws on top off
look at belt remember how it came off
now remove front panel
remove belt
push up drum hard
remove drum
now u can get too the heater
best of luck al
May 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
ASUS S6 Notebook Logo
501 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
