Question about Dishwashers
I have an Electrolux Dishlex DX303 Dishwasher. Recently it has been stopping early in the cycle and the display shows -10. The selected program is flashing. The cycle will restart by pressing the program button again but it no longers wash's right through the wash pe=rogram as it is meant to. I do not have the manual to trouble shoot and find out what this means. Your help would be appreciated. Regards Peter H
Hi peter, according to manual book -10 is not filling water fast enough. check inlet hose and valve, check pressure switch and pressure SW hose and clean sump filter which located bottom of tub that plastic strainer and stainless mesh clean them spotless. sometimes caused by this filter block the water passage and change pressure sw's leadings. and clean sump as well. b4 suspect PCB this filter cause many problem like not heating water, doesn't keep water. if dirty filter is the one you will save at least $300- for service man to come out and change the PCB for nothing. I think clean the filter doesn't hurt anyone.
Service Man K
Posted on Oct 16, 2010
I have an dishwasher dx303 recently it has been stopping early in the cycle and display shows -21 could you please help me what's problem? Thanks. Maryam
Posted on Jun 01, 2012
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Electrolux (dishlex) DX302SJ dishwasher all lights flashing. When I press program and start buttons together code 1C flashes.
Take the kick panel off the bottom. There is a tech sheet in an envelope under the machine. IT will have everything that you need to do to troubleshoot the machine.
Dec 02, 2013 | Electrolux Dishwashers
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
Dishlex dx303 error message 50
Our Electrolux DX303 had an i50 error. It was due to a water leak causing earth leakage current. So it's good it stops working if it detects a leak.
Our leak was from where the water goes to the upper arm (the pipe is made of plastic and has a plastic thread which isn't strong ie cheap). The pipe is located on the back right hand side once you take off the panels.
Apr 15, 2012 | Dishwashers
I am after a manual for the electrolux dishlex dx303. thanks for the help.
Hi I am Kelly.
This is not the exact manual but maybe it will help. (DX301)
http://www.dishlex.com.au/common/pdf/156987653_DX301.pdf
I searched for sometime and did not find a single DX303 manual on-line.
If this was not helpful just don't rate the post and maybe another expert just by chance happens to have a copy of the manual and can direct you to a link for the manual.
I just recall looking for this exact manual several times for other askers without success. I know for a fact I have lost over 3 hours searching for the manual your seeking. It just does not seem to be anywhere other than with the retailers in the stores... (you might ask for a copy)
Kelly
Sep 14, 2011 | Electrolux Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
Eloctrolux dishlex 302
You can download and view the manual HERE
You will need Acrobat reader to view this.
Oct 03, 2007 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwashers Logo
841 people viewed this question
Top Dishwashers Experts
Owen Barnes
