Question about RCA R52WH73 Projection Television
Screen has shrunk and picture is now tripled - RCA R52WH73 Projection Television
  • RCA Master
  • 17,130 Answers
The projecction width has reduced with the three guns going out of alignment to give the three images.
It is possible that the power supply voltage has reduced which has made the projection drop down to give this reduced size.
Check for possible failrue of the filter capacitor or the fault in the SM pre driver circuit, possible redduction of value of some associated electrolytes.
Check for visible signs of capacitor leaks or use a multimetter to confirm.
Posted on Aug 22, 2010
What do I check
take it in for a repair quote and if fixable at a reasonable price fix what is quoted
Jun 13, 2016 | Televison & Video
My sky box picture has shrunk
check your aspect setting
Sep 09, 2014 | Televison & Video
Flatscreen tv picture has shrunk to the upper left side of the screen
The TV is in Picture-in-picture mode. The small picture is the last active source. The bigger area is the current source connection, but there's no signal.
Read the manual about how to operate the Picture in Picture feature.
Sep 05, 2014 | Proscan 32LB30QD 32 in. LCD TV
Panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
Dec 28, 2011 | Panasonic Televison & Video
My picture size shrunk
you have a bad cap in the vertical section depending on your skills as an electronic tech see repairman
May 19, 2010 | Funai F42PDME 42 in. Plasma Television
Shrinking screen
check the user manual also can be misconfigured or check the source voltages and convergence
Sep 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Picture fault
Hi.
What is picture like if you change screen size to 4-3  is this picture size ok & fault only shows in the wide screen formats.
Oct 10, 2007 | Televison & Video
RCA R52WH73 Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
