Question about Samsung HT-DS610 System
My dvd plays fine until it gets to a certain spot and then it stops and starts and then it just sticks
    President:
  • 1,285 Answers
There is some finger prints or oil on dvd, you need two paper towels one dry and one a little wet (warm water)..take dvd w/left hand and with the right and damp towel go in a circular motion (one direction only) now with the dry towel ....... now play dvd, enjoy your feature
please feel free to rate the help
Posted on Aug 22, 2010
My panasonic dmr-ez48v freezes intermittantly when playing dvd's.
perhaps broken gear that moves the laser CARRIAGE contact avsystemparts.com
Feb 25, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Recording from VHS to DVDR was going fine,then I stopped getting a picture. DVD player is fine plays back recordings etc. However tape player starts to play shows picture then stops showing video and...
Possibly dirty video heads. I would suggest that you run a head-cleaning tape through the VCR deck to shift surface dirt off the heads. If that doesn't work, or it sort of works, but not satisfactorily, unplug unit, carefully remove top cover, and with the VCR deck in view, gently clean the heads with a soft cloth or special cleaning stick (these look like flat q-tips but are intended for VCRs - available from electronics/hobby stores) and some alcohol (methylated spirit will work if that's all you got - but isopropyl alcohol is recommended - available from the same places as the sticks) clean the guides (gently so as not to disturb their alignment) clean the pinch roller/capstan shaft - CTL (on the right-hand side of the drum) and FE (left side) heads as well. The whole tape path should be carefully cleaned. Refit top cover (carefully), plug unit back into power, wait until it completes its startup/loading procedure, then put a tape in. You should now have a playback picture with the sound. You only need to do this as required if head-cleaning cassettes don't work properly.
If none of the above cures your problem, then the heads are abraded/worn - let's hope that isn't the case here. This model does not use a built-in head cleaner.
Feb 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Skipping stitches and sometime the thread breaks.
Sounds like a tension problem maybe. Too tight tension will bend, and break the needle, especially if sewing fast in free machine embroidery, in this mode, the tensions have to be looser anyway. I can't explain why the wheel flagged and stopped, but experiment with tensions first.
Mar 27, 2017 | PfaFF Sewing Machines
My sony dvp-cx995v
Seems optical lens of unit is causing problem of No Disc.
Clean optical lens with cleaner disc and then try to play dvd.
If still same problem, take unit to local repair shop for fix.
Feb 12, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Staarting to not get past certain discs mennu screens.....
We have had out Toshiba P25-S509 for a very long time. It's a great laptop and watching DVDs with a wide screen was great; That is, until the CD/DVD player was no longer recognized by the computer. We took it in (still under warranty) to have it fixed, only to not work again after a couple of months.
Now YEARS have gone by and I have bought another Toshiba (M305D-S4831) which is great unless you try to reboot and it doesn't fully start up. That's for another review, not this one... So, back to the P25-S509 and YEARS later. We just received two 1GB memory cards, which are being used to replace the "stock" two 256 MB memory cards. Well, the computer is MUCH FASTER and THE DVD PLAYER FINALLY WORKS!!! Woo-Hoo! $98.00 investment in memory cards saved up from ditching the older Toshiba.
Hope this review helps someone out there that might have had the same problem.
Nov 03, 2008 | Memorex MVD2022 DVD Player
DVD Player freezes on some commercially produced DVDs
The microprocessor or memory componets on the player isnt functioning asits supposed too. This is rather troubling and there isnt any easy fixes possible.. My suggestion is seeing as its new return it and get a replacement. Chances are it will fail very soon.
Jul 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
Games want play
its highly possible that the disc is scratched (a scratch in a certain spot can cause a game to mess up at that precise spot in game play, i.e. when u try to start a match or start up the game) if u get it buffered (at a gamestop or the like) it might work again.
Mar 22, 2008 | Microsoft Xbox 360 Console
Recorded a DVD on computer but will not play on DVD player
dvd players play only certain kinds of discs and formats. Older ones played -R's, most newer ones play everything. You have to look in manual, or on box before you buy player. If it won't play -R,+R, -RW,and +RW's I pass it by. Find out if your player is limited to certain discs. Some will play VCD and some will not. Some will play DIVX and some will not etc. Stick to the discs and formats your particular player is compatible with.
Nov 29, 2007 | iLO DVD Recorder DVDR05
HT-WP38
cheapest and most logical start to the solution is to replace the optical block. looks like its focal point is drifting at a certain temp.almost impossible to pick up that problem without having that problem before. if i can advise,when you recieve the new part, unsolder the small bridgepiece that they put in for protection. if you dont, the unit will never work.
Aug 24, 2007 | Samsung HT-DB120 System
Dvd stops
Hi "DVD players with freezing video", is a common problem, and is usually a sign of a bad laser, or video processor, that give out after they heat up part way through a movie, but what you describe about fast-forwarding a bit, and the problem goes away, would lead me to believe that the problem is not either of those. It sounds like there may be possibly some obstruction on the sled rails that the laser rides on, or sometimes the nylon gear that moves the laser splits, or has dirt in the teeth that can cause this problem. It sticks at a certain spot, then once you get past that spot it operates fine. If it was a single disk player, I would say it would be worth taking the cover off to see what you could see, (being careful not to expose your eyes to laser radiation,)but being a multi player, it is very difficult even for a tech to watch the mech operate. I hate to say this, but I would advise you shop around for a repair place that has a low bench fee to check it out, and if it's dirt in the teeth, it should not be an expensive repair. I don't know what you paid for it, but Onkyo has been a high end brand, and it's a multi player, so it may well be worth it. I hope this helps you in some way!
Nov 29, 2006 | Onkyo DR-C500 Multi-disc DVD Player
Samsung HT-DS610 System Logo
35 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
