Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
What type of light bulb does the freezer use - GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
  • 8,197 Answers
May I get the model # so I can help you get the right bulb
Posted on Aug 22, 2010
Light bulb is not working. how to change it and what kind of bulb is it model: FKFH21F7HW
Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Feb 25, 2014 | Frigidaire FKFH21F7HW Freezer
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
Freezer light won't come back on .
Is that a florescent bulb in the freezer? Or is there some kind of light bulb in the freezer? If so, change the bulb. I'm not being funny. You give no information on what make, brand and year of the freezer to give you any help.
Apr 07, 2013 | Freezers
Hi, I have a Vulcan Deep Freeze 300L with no bulb in light fixture, Can you tell me what type of bulb and wattage should I buy. Not sure if these bulbs are a special type or not. I also need a cover for...
http://www.alliedappliance.net/_vulcan_part.html
aussie aussie aussie oy oy oy
hi from sonic boom electronics sydney above is a link to volcan parts australia they should be able to help with a cover as for the globe it is 240volt 20 watt pm5 connection
take care need more help feel free to call 0416380976
Sep 29, 2010 | Vulcan Freezer EXTWARRANTY-GCO2D Extended...
Power light not working. What type bulb needed for replacement?
model make of this unit is very helpful. let me know i got a parts book.
Apr 28, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
Changing light bulb in a 25 year old freezer
Whatever you do, you MUST unplug the freezer before attempting any repairs... there will not be any release buttons, nor any special installations for water safety... also, take care to avoid cutting yourself on the broken glass..
1) did the whole light bulb glass And internals come out, or is the internal part of the bulb still present?
2) verify that the light bulb is really a screw-in appliance bulb -- look into the center of the broken bulb and see if the metal base has internal ridges -- or if the metal base is smooth on the inside...
3)  if a screw-in appliance bulb:  3a)  if the whole light bulb glass AND internals came out, you will have to probably look very close inside the socket to determine the wall of light bulb base... it should be very thin and flexible and very unlikely you can unscrew it directly -- I've had to take needle-nosed pliers and gently bend and twist until the bulb base came out...
3b)  if part of the glass remains as well as the internal stem, I have heard that one could cut a potato in half and then push the internal part of the potato onto the broken end of the bulb and gently unscrew the bulb by twisting the potato... never tried this so I don't know if it will work -- if the internal stem is still intact, I'd use my fingers and try to gently turn it to unscrew the bulb
4) if it has smooth inside wall -- this is probably a bulb with small exterior pins -- the base should be a little more thicker than the screw-in type, so you should be able to push the bulb base in -- a little give in the spring holding it in -- if you feel this give, then turn carefully counterclockwise and it should pop out...
Again, turn off all electrical power to the freezer, Pull the Plug before attempting any repairs... remove all glass and handle with care...
Jul 25, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Hussman DCCG Freezer
are they the florescent tube type?? i suspect that the ballast went bad
Apr 15, 2008 | Hussmann Commercial Freezer DCCG-12
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
182 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
