Question about Compaq Presario 700 470024-192 Notebook
Thank you was able to pull the keyboard off now easily. Removed the clear plastic sticky off the back of the keyboard. Keys are not "stuck" but are not being recognized. Any idea of how to clean the inside of the keyboard? Was thinking about soaking it in water and mild laundry detergent, but not sure about that. It has dried sticky stinky dog urine inside the spaces of the actual keyboard. The good news is that the plastic sticker prevented the pee from getting into the computer so everything there is fine. If this doesn't fix I will probably just hook up an external usb keyboard, but would like to fix instead. Thank you so much!
    President:
  • 2,712 Answers
If you find that there are no contacts /membrane on the undersid of the keyboard, then use plain water to clean out the mess. However if you see that there is a film of plastic with contacts under it, then you may have to soak it in some isopropyl alcohol. You can even try using an old toothbrush dipped in the alcohol and brush the surface of the keyboard (not the underside).
The other option is to contact your manufacturer and see if they have spare keyboards for your model. Although if you ask me, it would be cheaper to go in for an external k/b. My advice if you are going for an external k/b is dont go in for wireless..they cause more headaches of their own :) Go for the corded, basic USB variety, which is many time more reliable.
Cheers and good luck!
IrishDruid
Posted on May 04, 2008
Dell inspiron n4030 keyboard not working
Shapsog,
You may need to turn off the Filter Keys option. Follow the steps below to turn them off.
Go to
1. Control Panel
2. Ease Of Access Center
3. Make the keyboard easier to use
4. Uncheck the "Turn on Filter Keys" option
You also may need to Check to be sure you don't have Sticky Keys enabled.
BY PRESSING THE SHIFT KEY FIVE TIMES
Without pressing other keys, press the SHIFT key five times to enable Sticky Keys. A window will be displayed asking you if you wish to turn on Sticky Keys Clicking Yes will enable Sticky Keys or click No.
If none of these steps work you may need to replace the keyboard or plug in an external USB keyboard.
Thank You,
Dell-Jesse L
Dell Social Media and Coimmunities
Oct 19, 2015 | Dell Inspiron N4030 14 Inch Notebook...
My number 1 key on the numberpad is stuck
Step 1:
What sort Of stuck ?
A stuck key on a keyboard is one of those annoying things. The typical desktop keyboard has about 104 keys, a laptop keyboard has a few less. The problem of a stuck key can be a hardware or a software problem or the key itself might be the culprit.
Hit the key several times. This will almost always unstuck a key. Clean the keyboard with an approved keyboard cleaner. These often come as wipes. People sometimes spill food and drink that can make keys sticky. Pop the keys out using a small knife or flathead screwdriver. Most keys pop right out and can be pushed right back in place. Look for something that might be blocking the key and remove anything you find.
Feb 10, 2013 | Dell Computers & Internet
Keyboard stuck
If you are addicted to your laptop, or are an overzealous typist, you may be dismayed when a key on your laptop becomes stuck. However, just because a key gets a little sticky, you don't have to run out to the computer repair shop. There are plenty of practical steps you can take to fix your stuck key right at home that don't require any fancy equipment, just regular household items.
1.Clean the area around the affected key. Use a damp cloth to clean the surface of the key (and surrounding keys) and then use a dry cotton swab to clean under the stuck key. Be careful not to pry the stuck key up with the cotton swab, as this could break the stuck key.
2.Press firmly on the stuck key. Sometimes after small dust or particulates are removed, the stuck key will pop back into place. However, if this is not the case, continue on with Step 3.
3.Pull out the fingernail cleaner extension of your fingernail clippers. This is the flat extension with a little hook on the end. Place the small hook under the left corner of the stuck key. A common reason that keys get stuck is that the collapsible spring becomes off-center. Gently push the key from side to side until it clicks into place. If this does not happen, you will need to disassemble the key completely.
4.Lift the top part of the key with the fingernail cleaner. You will see a collapsible plastic hinge (this is known as the Key Retainer) as well as a little rubber piece. Take both of these out. You will see a flat surface. Run the cotton swab across this surface to remove any dust.
5.Place the key components back in the keyboard. Place the rubber part on top of the metal circle you just cleaned with the cotton swab. Then place the key retainer (big side down) on top of it, and "click" it into place. It is very important to be careful with this step as these small parts break easily. Then place the stuck key on top of these parts and then give it a solid tap to click it into place. Your key should work now.
Sep 28, 2011 | Computers & Internet
Need to replace broken key on keybord. plastic appartus on key underside broke
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
Stuck keys thanks to girlfriends Margarita.board still works but keys stick. Getting rid of her want to save the keyboard. How can I clean? new sony viao wireless keyboard for desktop.
Not sure if this is different to a std keyboard but in cases like this I'd
Turn keyboard over, remove retaining screws noting position and order and take out the plastic membrane, wash thoroughly with mild detergent and dry thoroughly. Remove keys in turn, clean with warm water dry and replace. Any other stickiness an be removed with isopropyl alcohol or similar and a q tip or lintless cloth , gently clean. reassemble.
Feb 11, 2010 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
1 on the keyboard is stuck, can you help? Whenever I try to use my eee laptop for anything that requires typing, it runs itself off with 111111111 Please advise!
This could be due to the keys area being dirty and sticky. Make sure your laptop is powered off and disconnected from power then gently remove the "1" key by using a house key or paper clip. Be sure to get underneath the "1" key and pull up until the key pops off. With the "1" key removed, clean the area under the key with a lint-free cloth. Replace key when finished.
Jan 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
Our keyboard keys stick. Nothing has been spilled,but I find all of the keys seem to react very slowly. If I don't tap each key deliberatly, the letters don't show on the screen. I could sure use your...
Hello and thank you for using Fixya's services.
A can of air will fix this problem. You can find this at any electronics store. Turn the keyboard upside down and blow the air into the keyboard. This will clean the keyboard and anything stuck inside. Dust, food, etc. generally, over time, tends to get stuck in the keyboard and causes the "sticky" keys.
Hope this helps!
Nov 30, 2009 | Dell 0Y3740 Keyboard
I have a hp laptop model no dv 2046 tu...the problem i m facing is that my keyboard's ctrl key is stuck...whenever i press any key....a combination of that key wid ctrl is is taken...example....if i press...
This solution is for Windows XP.
If you see no physical sticking, then you may have "Sticky keys" on.
To look to see what your "Sticky Keys" Settings is at do the following:
In "Control Panel" double click "Accessibility Options"
A new window will pop up. The first tab is "Keyboard".
The first box at the top is "Sticky Keys" make sure that is unchecked.
"Sticky Keys" can be automatically turned on if you hold down certain keys for a predetermined length of time. Usually a box will pop up asking if you want to turn it on.
Thank you.
Please rate me.
Jan 27, 2009 | Computers & Internet
Sticky keyboard
You can carefully take off the keys and pop them back on. Use alcohol to wipe up any stickiness.
G'luck
Oct 24, 2008 | Acer Aspire 5100 Notebook
Acer 3500 keyboard
Let me start from the top.
1: removing the keyboard: as near as I can tell, at the top of your keyboard is power button etc,.. this cover can be removed.
once removed, there are at least 3 screws under it, once those are out there are 2 more on the bottom. NOTE:
could be that like on my Compaq and IBM the proper keys on the bottem are denoted by a small etching of a keyboard.
It may not be neccesary to remove the keyboard, so if it ain't broke.. don't fix it.
2: Fixing this keyboard is possible IF by stuck you mean they stick but otherwise work. My IBM for example ( used by
my kids on occasion ) has had sticky substances dropped onto the keyboard. I simply removed the appropriate keys,
cleaned them with alcohol and re-seated them. CAUTION: Pay attention to how they come off so you can put them back on
and be careful not to break the plastic connectors.
In closing,.. if all else fails and after cleaning and re-seating the keys dont work, buy a new one. They aren't that expensive if
you look around. I won't put a website here for an on-line store that carries them,.. but do a google search you'll find several
places.
Feb 24, 2008 | Acer Aspire 3000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
49 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
