Question about GE Profile Prodigy DPSR513GA Dryer
Turn start button. Dryer begins working; as soon as I release, the start lever it stops
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 22, 2010
I push the to start button and it turns over for a little while. It will stop when I release the button, or not. It may turn over again when I press the button to restart. It will not continue running...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The dryer will not start
heatman101
Aug 29, 2011 | Kenmore 74742 Gas Dryer
I have a Kenmore Dryer Model 11063942101. When I press the start button the dryer starts but stops as soon as I release the start button.
heatman101
Aug 10, 2011 | Kenmore 63942 Dryer
Kenmore Dryer model 63942 - Push statr button and the Dryer shuts off as soon as you release the start button
lint is stopping lever in motor switch....best use compressed air to clean it(should be 2 screws to remove it
Aug 25, 2009 | Dryers
Start button doesn't work properly
Hi, You have a motor going bad. The start winding is out on it.
The motor will need replaced.
Vic
Jun 25, 2009 | Kenmore 659 Electric Dryer
Dryer will not turn on and stay on.
Hello , bad news here , when you press the start button it sends power to the motor and then a clutch sets in and closes a set of points that then sends power to your element -if the clutch does not engage the motor will not continue to run or send power to the element and that is what is happening to your dryer.
not an easy fix at all , the clutch is bad and its located inside the motor and the entire motor would need replaced to repair this problem. they range from 80-100 dollars and would take about 1-2 hours to change.
let me know if you have any other questions.
Phil
Jan 12, 2009 | Dryers
Drum doesn't turn, start switch turns dryer on when held on but dryer shuts off as soon as start switch is released.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Dec 02, 2008 | Dryers
Dryer stops
your motor switch is gone you can either change the switch or motor you could try tapping the switch sometimes it will free the contact this switch is on the motor
Dec 09, 2007 | Kenmore 659 Electric Dryer
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
My Dryer Starts, then stops as soon as I release the button.
Its possible the dryer heat selector is at fault. If the timer inside does not move to the end of the heat cycle you may have further problems. Depending on how old the dryer and how long it has taken to dry garments, you may want to check that the motor has not gone bad causing an electrical overload. Faulty timers will cause extended drying times eventually putting a strain on the motor's bearings and electrical windings. You may want to get a replacement or get a repair estimate to repalce the belt, motor, drum rollers and heating coil components.
May 12, 2007 | Kenmore 63932 Electric Dryer
Dryers Logo
50 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
