Question about Maytag Performa PAV2200
MAYTAG MDG6200 AWW flame keeps keeping going out
My front loaded Maytag dryer gets a flame and the coil gets red hot but within 30 seconds the flame goes away and the coil does not stay on (red hot). I am wondering what part I need to change? Please help I have THREE KIDS AND A HUSBAND and the clothes are PILING UP. Thank You Very Much.
  • 487 Answers
Your thermostat is broken.
I think the gas 5 wire or the heat limit
FOR THESE PARTS LINK
or what i would check first is the fuse on the blower housing which is a thermal fuse. A regulat ohm meter /resistance meter can do the trick. No resistance should be measured or very low on this fuse. If uninfinit restistance this one is broken.
It can also be the limit thermostat . Measure when cold. > low resistance.
This is another link for PARTS
Good luck
Posted on May 04, 2008
I would like to find out if my Maytag Neptune dryer has heat coils or just a Flame sensor
Go to YouTube and type in - Maytag Dryer heat coils and see if it comes up. Also type in Maytag Neptune Flame sensor on the next search.
Oct 05, 2015 | Maytag Dryers
Gas dryer replaced flame sensor and still not getting hot
replace the gas valve coils on the top of the gas valve they get weak from the heat and can't keep the gas valve open
Jan 11, 2013 | Maytag Dryers
I HAVE A MAYTAG DRYER MODEL MDG4000BWQ AND IT WORKS FINE BUT QUIT HEATING THEREFORE IT WILL NOT DRY THE CLOTHES. i CAN HEAR WHAT SOUNDS LIKE THE IGNITOR CLICKING OR TRYING TO FIRE FOR A FEW SECONDS WHILE...
http://www.fixya.com/support/t6223020-maytag_dryer_model_mdg4000bwq
to Wayne (vmsem) : model MDG 4000BWQ Maytag Gas DryerI have the same dryer and experienced a similar problem. If you hear a click followed shortly by a gas ignition (whoo-oosh sound) but then there's no significant heat at the beginning of a drying cycle, the flame went out..... probably because you have a bad coil (aka solenoid valve). If the dryer is left on, the click-whoosh event will repeat periodically--I don't recall how often, perhaps 5 minutes. To access the coils you will need to remove the front panel of the dryer....(it's simple). Begin by locating the door hinge screws when you open the door.Remove the screws that mount the hinges to the cabinet--leaving the hinges attached to the door itself. The door should still hang there loosely. With the door open, gently lift the door so the hinges will slide upward in the slot where they mount, then pull gently to slide the hinges out of the slots. When you remove the hinges you can see why they require the up-n-out motion. Now remove the screws (2) on the other side of the door opening--they are holding plastic "bumpers" attached to the cabinet just inside the door. The top front panel should now pull away from the cabinet--tug at the top R and L portion of the front panel but not at the base--it is hinged. Then allow the top of panel to drop forward and down (within 1 ft. of the floor?) until it can be easily pulled away from the cabinet (off of the brackets that hinge the base of the panel). Now you can see what's happening and troubleshoot.
WARNING --If you haven't unplugged your dryer BE VERY CAREFUL not to touch exposed wires, igniter, etc. and if you activate the motor, keep your hands or anything else away from moving parts, including the dryer drum.
CLICK--WHOOSH--FLAME GOES OUT:Chances are that your problem is with one or both "coils" that are mounted about 6" in front of the burner tube (metal duct where the gas ignites).
There's a bunch of red, white, and black wires attached to little plugs that are connected to the coils. They can be tested for continuity using an ohm meter and more on that can be found online. If the igniter is bad it will not get red hot and the flame will not appear. You can observe what happens by starting the dryer and watching. BE CAREFUL !! (Hold the button in--where the door used to hit it. Or, temporarily replace the door without the front panel). The igniter should glow red-hot within 10 seconds and within 30 seconds the flame should start. If the flame starts but goes out after a few seconds it's more than likely a bad coil. If the igniter never gets hot, look closely at it (before removing it) with a flashlight to see if a crack or break is evident. BE SURE TO UNPLUG the dryer before attempting to remove the igniter (or other parts) OR wires connected to it--SHOCK HAZARD! Avoid touching the metal igniter element unless you're sure it's bad--Touching or bumping a good igniter may cause it to fail. Directions on the procedure can be found online. .
Recently I encountered a less common problem with my 11 year old dryer that also prevents it from getting hot--(no flame at all). The igniter gets re-hot and stays red, but no fire. There's a (1x2-inch black box) heat sensor mounted over an opening on the burner duct, very near the igniter. As the sensor is heated by the ignitor, it's supposed to trigger the coils and allow the gas to flow for ignition. I understand that the sensor rarely fails but it can happen. More details about troubleshooting and replacing bad parts can be found elsewhere. I hope my comments were helpful. ("HandyAndy")
Sep 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The flame goes out after about 30 seconds. I have
one of the thermal sensors may be bad.
you may also have a faulty ignitor even though it glows it maynot be drawing enough current to keep the regulator open
May 28, 2010 | Maytag Neptune MDG7500AW Gas Dryer
I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
Jul 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The heat (gas flame) goes out after dryer has been running for about 10 minutes and drum keeps turning but clothes never get dryed. Model is mdg6200
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
This could also be caused by a bad set of coils as well. the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
**The most common problem spot here will be a defective set of gas valve coils.
Jul 08, 2009 | Maytag Performa PAV2200
Dryer flame shuts off after about 30 seconds
this sounds like a clogged vent more than a thermostat. go outside with the dryer running and see if hot air is blowing out the vent. if not check outside vent for birds nest etc, inside make sure the vent is straight any dips in vent could cause water to build up clogging the vent. try this first if it doesn't work write back
Jan 23, 2009 | Maytag Dryers
Flame will cut off in 30 second
check the loose blower wheel and lint in the filter housing phenom associated with these dryers. The operator coils will get hot and quit and cool down after several hours and work again making it imposible to pinpoint a solution. Replace those coils. $20 bucks.
Dec 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
The flame does not stay on for more than 30 seconds i have replaced the coils
Hi. thanks for the question . The problem is with the air flow. Maytag dryers are known to have a blower failure . replace the blower . And clean all vents. Thanks the appliance doc
Sep 30, 2008 | Maytag MDG7600AW Gas Dryer
Washing Machines Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
