Question about Canon PC-920 Black and White Copier
How do I clean the transfer charger?
Hy PC-920 copier is printing evenly spaced vertical lines. According to the solution given, was to clean the transfer charging unit.
How do I do that?
  • Anonymous Oct 31, 2008
    I was given a PC920,and when I turn it on it makes a sounds as though it is ready to go but when I press the Green print button it does Nothing. Is the toner cartridge just empty? Or Do I need to take it to a repair shop?
    Bob
  • 3 Answers
Their is a transfer charger in convare unit if your machine. by open a screw put it out and with the help of a small brush clean this transfer charger.
Posted on May 05, 2008
Black lines on printed documents
Vertical lines? How many pages have you printed? Check the counter and then answer to my post. Maybe you will need to replace the MK. Check the surface of optical cylinder for scratches. However, if the MK is not at the end of his life, and the cylinder surface is not damaged, you will need to clean the charge roller and then to execute an Drum Refresh from Service submenu. This is the most frecvent problem that I meet, related to vertical lines. There could be other bad components, but you will need to check first the drum unit.
May 12, 2014 | Kyocera FS-920 Laser Printer
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Vertical black line
problem in drum charger clean it OR developer unit clean
Nov 09, 2012 | Ricoh Office Equipment & Supplies
Printing colored lines
Vertical black lines:Check with another cartridge..Check Teflon sleeve.Vertical white lines:Replace cartridge.. replace transfer roller..Clean laser scanner unit( technical skills required) Horizontal Black lines:Replace cartridge..
Jan 31, 2012 | HP LaserJet 5000n Printer
Black line on print-outs
When u found any extra black or white vertical line, we can check 3 possibility:
1) check the toner container. U may have to replace a new 1 if necessary.
2) clean the charger wire. Just slide the Charger Cleaner (green color) backward and forward 3-4 times to clean the charger wire, then return to its original position.
3) check the charger cleaner is it in its original position or not?
YBC (/\)
Jan 21, 2009 | Kyocera FS-920 Laser Printer
Magicolor 2430 DL vertical lines.
pleas take a closer look at the pc drum and transfer belt, if there are also stripes then you find a problem, stripes on pc drum means new pc drum and on TBU there is possible to clean the cleaning unit but not in every case. if cleaning doesnt help new TBU
Sep 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
White Lines
My magicolor 2430 dl prints fine until i print a photo then it leaves vertical streaks down the page, how do I correct this and if its dirty how do i clean it.
jim
Jan 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Canon PC-920 Black and White Copier Logo
177 people viewed this question
old marine
old marine
