Question about Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
The machine is not sucking out moisture why - Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
  • Danby Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 29, 2010
There is no water going in the container can you Tell me why this is
some reasons i can think of are
(1) operator not famliar with operation of dehumidifier , Ie controls not set properly or interlocks not made on bucket full switch , just because you hear a fan running doesnt mean it's working
(2) unit defective , or etrreemly dirty inside filters never cleaned in its lifetime
(3) operator askin machine to remove too much moisture from air than it can so now room has no excess moisture to "give up" settings less than 53% rh could cause this problem , this of course is precusor to unit works very well at first then sort of tails off days later
Feb 11, 2015 | Dehumidifiers
Dehumidifier is running but not sucking out any moisture out of the air
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
May 27, 2011 | Sunbeam Evaporative Humidifier...
Hi! my dehumidifier is on but it doesn't sucks/gather moisture anymore?why?I've clean the filter but still problem persist. what to do? Help!
heatman101
Feb 15, 2011 | DeLonghi Dehumidifiers
It runs but does not suck moisture out of the air
heatman101
Jul 04, 2010 | Haier HDN305 Dehumidifier
What are the settings (humidity)from 40 upwards on my micromark ? . Is the lower setting to take out most moisture ? Thank You
40 is 40% humidity in room - that's really dry.
For moist area you usually want 50 or 60%.
Dehumidifiers are for damp areas. If temp ouside is below freezing, inside house is probably already too low.
Dec 01, 2009 | Dehumidifiers
PROBLEM IS FAN WORKS BUT NOT SUCKING ANY MOISTURE
see to it that it run to right direction together with fan direction
Jul 30, 2009 | Dehumidifiers
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
Apr 02, 2009 | Maytag M3DH30B2A Dehumidifier
Dehumidifier efficiency
I'm surprised that you are trying to dehumidify if you are in the northern hemisphere right now.
But, before you go off trying to fix the refrigerant, see if you can get a glass of ice water to sweat near the dehumidifier. While relative humidity might be high in cold climates right now, it's a relative number, as the total grains of moisture is far lower than what it would be in a warmer climate. Cold air saturates easier, because it holds less, moisture.
Most people use a humidifier in the winter because they want to saturate the air with water, which is better for the human body, and minimizes static electricity.
I can help you diagnose the dehumidifier if you want. The coil should only get to 40 degrees or so. But the sweating glass of water will tell you if there is enough moisture in the air for the dehumidifier to wring out.
Jan 30, 2009 | Haier HDN655E Dehumidifier
Model HDN455
Check the coils at the back of the dehumidifier to see if there is any frost buildup on it. If there is, turn off the machine for a while until the room warms up and melts off the frost. The machine works by condensing the moisture in the air over these coils, so if the coils are frosted over, or are not cold enough, the moisture cannot condense. If the coils are not cold enough, you may want to get it refilled with refrigerant. You will need to take it in for servicing in this case.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Aug 31, 2008 | Haier HDN655E Dehumidifier
Unable to control the maching
Are you sure that this is a timer issue because my research does not list this unit with a timer. It does have a humidistat which could give the operation that you describe depending on where the humidity level is set. You should be able to go to the menu and select the mode that the unit is in. If it is set to run until a certain moisture level is reached it sounds as though your unit is probably working the way it is supposed to. Generally that is the mode that most people would want. If you want it to remove more moisture readjust this setting to a lower percentage. Your operation manual should explain the procedure. Good luck.
Jun 21, 2006 | Danby DDR600R Silhouette Dehumidifier
Dehumidifiers Logo
472 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
