Question about Health & Beauty
My fisher and paykel CPAP Sleep style 600 stopped working during the night and had the error code E4 on the display. We had not had a power failure to the home. I read the manual but i couldn't find anything to help. I tried turning the power off for a minute or so to see if it would reset the machine. Didn't work. I changed the air filter. Didn't work. I checked to see if there was any moisture around the heating plate and there wasn't. I Held the main start button down for 6 seconds. Didn't work either. Please can you help?
Showing Error Code E1
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Aug 31, 2016 | Fisher Paykel Fisher & Paykel SleepStyle...
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Why does my Fisher and Paykel DD605SS stall part way through wash cycle?
I'm not sure of this, because the manual does not have an error with a E. I can fine error F4. It says it encountered a faulty temperature sensor or element. If the heating element burned through the night you circuit breaker tripped (Sure it was not the ground fault circuit breaker?), then the dish washer can't heat the water, so the program can't continue. The program stops (waits) till the chosen temp is reached. If the water stays cold the program can't go on.
So also check the heater in the machine. I hope you are aware everything in the machine runs on high (or at least dangerous) voltages, so be careful not to work in the machine when it is still connected.
Jun 15, 2014 | Fisher and Paykel Dishwashers
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
How do you know which CPAP snoring masks are best for you?
FOR ME I HAD TO HAVE A SLEEP STUDY DONE. IT IS A 2 DAY PROCESS. THEY HOOK UP ALL SORTS OF PROBS ON YOU AND MONITOR YOUR BREATHING. THE TEST WILL SHOW HOW MANY TIMES YOU STOP BREATHING. THEN YOU GO IN ON ANOTHER DAY AND THEY TRY DIFFERENT MASK DURING THE STUDY. ONCE YOU GET ACCUSTOM TO IT THEY MONITOR YOUR SLEEP AGAIN. THIS TIME, IF IT WORKS, YOU SLEEP THE REST OF THE NIGHT. FOR ME IT WAS WORTH IT.
Feb 13, 2013 | Health & Beauty
What is CPAP? I know it's something to do with sleeping and snoring.
CPAP stands for Continuous Positive Airway Pressure. It involves wearing a pressurized mask over your face while you sleep at night to help force air through the airways.
CPAP is used to treat sleep apnea and heavy snoring but the machine is very noisy and it's not comfortable to sleep with, so it's worth trying other solutions before turning to CPAP for help.
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
E4 error fisher and paykel dishwasher
There is a Y shape pipe under the sink's piping & it was blocked so I drilled & open a hole then the machine could has drained & worked.
Nov 08, 2012 | Fisher and Paykel Dishwashers
Dryer turns off after approximately 20 seconds. Error code E4
E4 Tumbler rotation failure If during a cycle the tumbler rotational speed drops to 0, all outputs will be turned off and error code E4 will be displayed.
May 17, 2011 | KitchenAid KHGV01RSS Dryer
Machine won't start
Hi there
i'm not sure if the fisher and paykel machines are any different in new zealand compared to where you live, but the only thing i can think of if it isn't displaying a fault code is if this machine is fitted with a reed switch(these make sure the machine stops if the lid is opened during operation) this may be faulty and staying open causing the machine to stop when the lid is closed. Hope this helps.
Jul 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Health & Beauty Logo
2,029 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
