Question about Sta Rite StaRite Duraglas Pump 1 12 HP Single Speed
I have a 1 1/2 hp A.O. Smith motor with a Stayrite pump. Motor was rebuilt by my motor/pump guy last spring and not put into use until 6 weeks ago with a rebuilt stayrite pump. Yesterday the motor started smoking and cut off. It will then come on again and then cut off while smoking. Why is this happening on a rebuilt motor after only 6 weeks of service?
  • tarheel2fl Aug 23, 2010
    No lightning strikes at my house or surges. Motor was in storage for about 4 1/2 months after I was told that it was rebuilt. It was then put into service for about 6 hours a day for 5 weeks....then poof, it smokes and cuts off. Maybe Greasy dropped a bone in it!!
  • Sta Rite Master
  • 1,338 Answers
LIGHTING OR POWER SURGES ARE THE BIGGEST KILLER OF PUMP MOTORS. ASK THE GUY WHO REBUILT IT IF HE CAN HELP YOU OUT. I'M LOCATED IN FLORIDA AND ITS THE LIGHTNING CAPITAL ! LAST STORM WE HAD IN 5 MINUTES THERE WAS 1000 STRIKES AND THE LAST BIG STORM 68,000 STRIKES. HECK I'VE BEEN HIT AND SEEN STRIKES JUST YARDS AWAY FROM ME.. COOL, BUT NOT , IF'N YA KNOW WHAT I'M SAY'N
Posted on Aug 23, 2010
Testimonial: "Very helpful answers. Thanks"
  • Jay Finke
    Jay Finke Aug 23, 2010
    OH I KNOW THE GUY THAT REBUILT IT STUCK A TIMER ON IT, SO IT WOULD GO UP IN SMOKE, SO HE COULD REBUILD IT AGAIN FOR YOU.. I HAVE HAD MY MOTORS LAST 8 YEARS AND THATS PUSHING THE LIFE OF A SHAFT SEAL THERE 3-6 YEARS. DID YOU MAKE THIS GUY MAD ? I FEEL BAD FOR MY CUSTOMER THAT AT LEAST DON'T GET A YEAR OUT OF MY MOTOR REPAIRS AND HELP THEM OUT.
    BUT IF YOU RAN OR STARVED THE PUMP FOR WATER AND IT HAS LEAKED WATER INTO THE MOTOR , THAT VOIDS WARRANTY AND IS NOT THE RE-BUILDERS FAULT !
  • David Spradling
    David Spradling Apr 16, 2016
    surge protectors will help
How can I run my aosmith 1hp pool motor on 115v?
LOOK ON THE MOTOR LABEL IT WILL HAVE A PICTURE ON HOW TO CHANGE IT, OR TAKE THE COVER OFF THE BACK AND LOOK CLOSE YOU WILL SEE HOW TO CHANGE IT.. jay the pool pump motor repair guy in longwood Florida 32750 .. BEST TO RUN PUMP ON HIGH VOLTAGE , IT WILL RUN COOLER AND LAST LONGER AND CHEAPER TO RUN $$$
Sep 21, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
Need ao smith replacement motor for anthony pool pump not sure what motor fits that pump
a rebuilt motor is the cheap way $85 ,new around 200, the impeller will need to be ID to get the right size motor. search for your local pool pump repair guy with free motor testing, use your zip code in the search. you might get your old motor rebuilt and thats even cheaper .. CLEAN POOL IS A SAFER POOL .. VOTE COMMENT .. thanks jay
Aug 16, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
Have 2hp northstar pump and its humming and flipping the breaker and then stops. How do we get the pump apart to see if we need to replace motor or propellor?
THIS IS A HARD PUMP TO WORK ON ! TAKE THE QUICK FITTINGS OFF AT THE TANK AND DISCONECT THE POWER LOOK TO SEE HOW TO PUT THE WIRES BACK UP (PICTURE) AND SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. WARNING THE HP IS MISLEADING ON THESE PUMPS , YOU MIGHT HAVE A A 2.60 HP MOTOR.. LOOK FOR THE SF ON THE MOTOR LABEL .. HAVE THIS READY WHEN YOU CALL TO FIND A MOTOR ! REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My A.O. smith pool pump doesnt seem to be getting electricity. It makes no noise at all when you turn it on. We had a storm last night I don't know if it tripped some sort of switch. I have checked the...
VOLT METER TO THE 2 LINES 230 OR SO ? THE MOTOR MAY BE BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY..USE YOUR ZIP CODE ... GOOD LUCK AND VOTE FOR ME...JAY
May 31, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Sta Rite StaRite Duraglas Pump 1 12 HP Single Speed Logo
357 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
