Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
I have an A.O. Smith HP 1 1/2, 115/230V, KW 1.1, PH 1, Code 1, RPM 3450, Model C48L2PA103, SER 1189 THERM PROT CET50ABM. My power source is 115Vac. I am replacing some wiring and need expert help to verify that the wiring between the motor and the terminal panel is correct, as shown below. Wiring from motor to terminal panel: PURPLE connected to terminal "A" under the panel WHITE connected to terminal "A" BLACK connected to terminal "L1" Wiring from Thermal Protection (TP) to terminal panel: BLUE from TP terminal 1 connected to terminal "L2" BLACK TRACKER from TP terminal 2 connected to terminal "A" YELLOW from TP terminal 3 to capacitor. Wiring from power source 115 Volts: WHITE to terminal "L2" BLACK to terminal "L1" GRENN to ground screw YOUR HELP WILL BE HIGHLY APPRECIATED. THANKS AND REGARDS.
5 Suggested Answers
SOURCE: Replacing new AOSSQ1152
What's the source of the info that the two orange wires are Low & High?
Orange is an unusual color, but I'd say, with 99.999% certainty, that if you put a voltmeter across the two orange wires, it'll read 220 volts (nominal).
The two orange and one white lead give you the ability to run @ 110 volts -- there will be 110 volts between one orange and white and also the other orange and white.
For this motor you only need the two orange wires which will give you 220 volts between the two. Cap off the neutral/white wire (not needed) & connect the two orange wires, one to L1 and one to L2 on the motor (L = Line). And don't forget to connect the ground...
Charlie
P.S. You should also have a GFCI on this circuit.
Posted on Sep 18, 2009
  • 66 Answers
SOURCE: Wiring new motor
I am assuming you are running 110 vac. Usually there is a diagram on the plate with the motor specification. You want the low voltage for110 and high for 220 motor wiring diagram you connect the motor as shown. If it is not on that motor it maybe on the old one they are usually the same.
You will need wire nuts to tie together the wires.
Note if this is a capacitive start or switch start. Allot of pool pumps are Switch start.
Posted on Mar 24, 2010
  • 336 Answers
The L1 and L2 are the load terminals. Connect the black wires to the L1 and L2 and the green one to the green colored screw.
Posted on May 16, 2010
john224
  • 1378 Answers
SOURCE: need to know what color
Thank you for posting your question here on Fixya.com.
Part of your problem will be the snake has a reversing switch so it is not as simple as just wiring two line leads. I assume you have a DPDT switch for reversing it? If so line goes to the center posts/terminals, motor L1 and L2 go to one end, motor red and black to the other end, and a jumper crisscrosses from end to end allowing the reversing.
In essence, what has to happen is in one direction motor L1 and red get power from one line and motor L2 and black from the other; to reverse motor L1 and BLACK get power from one line and motor L2 and RED the other. All of this assumes you are connecting to 115VAC since that is the portion of the diagram you reference. If not, add a comment with what you are connecting to.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 14, 2010
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
What is the problem fault code p1601
Toyota Hilux?
wow no year
, you do make it so hard to answer but is 96+
P1 means factory code, so autozones may fail.
5th generation 1996+
Engines:
  • 1988-1995: 1.8 L (1,812 cc) 2Y-U I4, 58 kW (79 PS; 78 hp) at 5,000rpm 140 N·m (100 lb·ft) at 3,200rpm
2Y I4, 61 kW (83 PS; 82 hp) at 4,800rpm 140 N·m (100 lb·ft) at 2,800rpm (export markets)[11]
  • 1989-1995: 2.4 L (2,366 cc) 22R-E SOHC EFI I4, 84 kW (114 PS; 113 hp) at 4,600 rpm and 192 N·m (142 lb·ft) at 3,400 rpm
  • 1989-1995: 3.0 L (2,958 cc) 3VZ-E V6, 112 kW (152 PS; 150 hp) at 4,800 rpm
  • 1989-1997: 2.4 L (2,446 cc) 2L diesel I4, 61 kW (83 PS; 82 hp) at 4,200 rpm and 165 N·m (122 lb·ft) at 2,400 rpm[12]
  • 2.8 L (2,779 cc) 3L diesel I4, 67 kW (91 PS; 90 hp) at 4,000 rpm and 188 N·m (139 lb·ft) at 2,400 rpm
my wild guess is the 2.4L due to OBD2 status. only...you need to say..
my motto:
NO YEAR
NO MODEL
No engine size. (or transmission type A/T or M/T?, if that is in question)
NO HELP (or your joy)
No country , too , is a royal pain , all cars are different by country (laws)
Jan 09, 2014 | Toyota Hilux Cars & Trucks
I need to replace a 1hp cont pool pump motor and dont know which 2 get... please help
Probably, I assume everything is c-face and it has enough power.
Jun 25, 2013 | AO Smith Plumbing
Trouble 3 hp motor
What kind of problems are you having with this motor?
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
How do you wire a type b 3450 rpm mod.c48k2pa105c5 motor to electrical box
two red wires means 220 volt those are both hot green is ground
red to L1 2nd red to L2 then green to ground ( to case) make sure on side of motor it is wired for 220 volt
Apr 03, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
Someone cut the plug from a 230V Craftsman Compressor and wired on a 120V plug and plugged it in. What type of damage could have occured?
You should be okay. It just ran at half speed while it was on. If had been the other way around (hooking up 120v motor to 240v socket) that would have killed the motor.
Jan 30, 2013 | Pool & Spa
Looking for a wiring diagram for an A.O. Smith Motor. Label partially tore off. Can read 56C fram, 16.2/8.1 Amps (assume 120V/240V, 1 ph) 3450 RPM, 1.4 SF, Type UC, partial part # ...D609FM
That actually appears to be part of the serial number, not the part number at the end of your post. What are you trying to accomplish? With a description of your terminal board and the current wire arrangement I should be able to tell you what you need to know. Another option would be to contact us through our site at www.arrowmotor.net and send a picture of the board.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 17, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
147 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
