Question about Toshiba SD-K741 DVD Player
My Toshiba SD-K741 dvd palyer is not playing dvds anymore the screen continues to say loading.
techman
  • 3130 Answers
SOURCE: Disc loading, playing and then freezing
sounds as though you may have a slider problem or something is blocking it. The slider is what holds the laser assy as it slides along it like a rail while the motor drives the slider by a gear shaft system or a belt system.. I've seen in the past the grease or lubercation on this slider can harden up and ive also seen something getting inside like paper or little army men who wanted to hide out and was assisted there by a wee one. although these are common, another problem is that the tracking curcuit could also have a fault like alighnment or defective part now that would also include the tracking or slider motor too. Good luck
Posted on Mar 28, 2006
SOURCE: Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Posted on Aug 19, 2007
simplemitch
  • 752 Answers
SOURCE: Toshiba SD-2050 problem reading discs
If it reads only the first track, it sounds like a mechanical obstruction of the laser assembly (something is physically blocking it from travelling on its rails). If you are so inclined, try removing the deck lid andgently pushing the laser (in an area where there's nothing fragile) along its track to see if it frees up. It doesn't usually take much.
Posted on Sep 20, 2007
  • 537 Answers
SOURCE: Can only play DVDs for one region code.
Most DVDs can only play DVDs from a single region. However, they sometimes allow you to change the region at least one time. Another option is to make your DVD player region free. This is a hack that can be performed. Once you do this, you can play DVDs from any region.
Please see the following link for more information:
http://www.videohelp.com/dvdhacks/toshiba-sdk760/6898
Posted on Jan 17, 2008
SOURCE: won't open...
Hey this is a great site!
I was having a similar problem with my Toshiba SD-K860. Bobbyj, thanks for the link to the SD-4900 service manual, it was extremely helpful even though it was a different model. I could not find an emergency eject pinhole, and leaving the unit unplugged for a while did not help (two suggestions found on other sites), so I simply took the whole thing apart, got the disc out, found the eject slider on the bottom of the tray, massaged the tray open and closed, and put everything back together again. The connections were solid and the belt was in tact so everything seemed to be fine. Once I reassembled and powered it back up it worked again!
I posted a more detailed solution on my problems to solve site, which is similar to this one:
http://problemstosolve.com/solved/toshiba-sd-k850-wont-eject-solved/
Posted on Jun 10, 2008
My toshiba sd-3205 will not load any of my DVDs anymore, the discs I insert into the player are in perfect condition and have loaded previously when the DVD player was working. it always says...
Probably dirty pick up lens.
Get a lens cleaning disc and run that and see if that cures problem.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba SD-3205 Multi-disc DVD Player
I have a Toshiba DVD player SD K741. For the past few days, when I load the dvd, I receive a message on my TV screen "Incorrect Disc." What can I do to correct this?
incorrect disk error are common with the user putting in a disc that is not compatible with the player, in most cases it would have been a RW, that was written incorrectly. If this is not the case and it is a original disc you might want to purchase a cleaning dvd witch goes in and cleans the lens.
If that does not work then the unit's lens might be defective at this point.
1. Try other disc
2. try a cleaning disc
If those do not work then the issue is with the lens.
Thanks for your question please do not forget to leave a rating.
Aug 31, 2010 | Toshiba SD-K740 DVD Player
Our sd-k741 player is playing previews but not the actual movie itself. Once the previews are finished, we get to the main menu and then we hit "play movie" and we get an circle with a slash through it and...
www.tacp.toshiba.com/tacpassets.../sd-k741/docs/sd-k741_om_e.pdf
If it does this with Any/Every movie no matter what, then your "Brain" in your unit, has gone faulty, and is freezing at the Load the Movie loading instructions, perhaps bad RAM, or a HDD problem whatever, you will have to get it serviced.
Jun 01, 2010 | Toshiba SD-K741 DVD Player
Dvd player says loading and won't play dvd
Disconnect the power,push the eject button and connect the power while pushing the eject button.
Dec 01, 2009 | Televison & Video
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Won't play Region 0 and NTSC dvds anymore
Do you have the output video type set correctly?
Jun 06, 2007 | Toshiba SD-V55HT System
Toshiba SD-K741 DVD Player Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
