Question about GRY Viore RPT50V24DHD 50" HDTV DLP TV
I need to reset a lamp timer on a Viore tv set
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My viore tv wont stay on it keeps going off by its
Ur tv the projection lamp,inside the tv now,been on an in used about 4 or 5 hours a day,the bulb been inside tv about 1 1/2 or 2 years?The projection lamp life is over,reqiure changing?Turn tv on hear alot of clicking too?The board call the Ballast board also require changing too,this Ballast board help to ignite the projection lamp.
Jul 24, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
Tv comes on for about 20 seconds then shuts off and the timer and the lamp lights flash on and off
is a inverter board defective, and shutdown auto. needs to replace inverter board. send to repair.
Feb 14, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Set timer
You did not post model number of TV so try below method to reset lamp timer.
Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
GRY Viore RPT50V24DHD 50" HDTV DLP TV Logo
484 people viewed this question
Top GRY Televison & Video Experts
Electro Med Services...
Are you a GRY Televison and Video Expert? Answer questions, earn points and help others
